Airspy HF+ Discovery Server. Online now.
If anyone would like to have a play, my HF+ Discovery is online via SDR# SpyServer at sdr://92.4.75.197:5555 I'll leave it up for as long as I can but will probably be using it myself later. The Korner is beaming 190°.
Have fun!
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Receivers: * Sony XDR-F1HD (PC controlled via Seeeduino board & XDR-GTK software v.1.0) * Elad FDM-S2 SDR * Airspy HF+ Discovery * Airspy R2 SDR * Airspy Mini * SDR Play RSP1A *
Antenna: P.Körner designed 19.4 Yagi (with improved gain & F/B ratio) horizontal at 11m agl / 92m asl (http://www.ukdx.org.uk/fm/Korner%2019.4 ... 4_yagi.htm ) on a Tennamast 7.6m telescopic / tiltover mast
( http://www.ukdx.org.uk/fm/Tennamast.htm ) * GP cut for ~30MHz * TGN ULNA 3018 Mk.IV Band 2 masthead preamp * CCW Multicoupler feeding all tuners/SDRs 8 * Yaesu G1000DXC rotator *
Software: SDR# v1714 * SDR Console v3 * Elad FDM-SW2 v3.019 * RDS Spy v1.03 *
Propagation maps produced by FMLIST http://www.fmlist.org/ul_login.php?sprache=en
Propagation Maps and TX sites logged for the Month maps at
http://www.ukdx.org.uk/fm/FMLogs/Prop%2 ... 20Maps.htm
All-time FM log (from 2003) and current month's log at http://www.ukdx.org.uk/fm/FMLogs/FMLogs_index.htm
All-time Meteor Scatter Log map at http://www.ukdx.org.uk/fm/MSMap.htm
YouTube Channel: http://www.youtube.com/c/MikeFallonSussexFMDX
Have fun!
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Re: Airspy HF+ Discovery Server. Online now.
Nice Mike
After quick scan 87.7 and 90.9 Spain
Ruud
I will try it also if you are again online!
Thanks Mike!!!
Just heard on 91.2 Mhz Spain
Thanks all. Glad you're enjoying it. I'll leave it running overnight, at least to early morning anyway. Now beaming 90°
Mike
Mike
Good morning Mike heard some german stations
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
The Airspy HF+ Discovery work's verry well! Thanks that we can try the SDR!
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
Thanks Ulli. Yes I'm very impressed with the Discovery. I'll leave the server up for now until I need to use it. Now beaming 120°.
I'll leave the server running overnight. Beaming 150
Mike
Mike
Mike, are the French Stations ever so strong like now? How far is the French Coast from your Location?
Best Greatings
Ulli
Best Greatings
Ulli
Yes, the French stations are always that strong. Yesterday's conditions were flat but when there is a lift they are even stronger! The nearest point on the French coast is around 110km from here. Dieppe is 125km and Paris 270 km.
I ask you, because some of them are strong like a local station.
I'll leave the server up for a while. Lots of German stations coming in now. Beaming 80. Try using a narrow bandwidth (~80kHz) and tune slowly up/down the band.
Mike
Mike
Hello Mike, does the peaks above 100Mhz come from a switching power supply?
Airspy Discovery is back online now. Lots of very good German and Swiss tropo about. sdr://92.4.75.197:5555
Have fun
Mike
Have fun
Mike
