Phil75
Beitrag von Phil75 »
highpoint hat geschrieben: So 7. Jan 2024, 15:47
Phil75 hat geschrieben: So 7. Jan 2024, 15:33 Habe eine Frage zur Version 4.2.1
New DAB Tab "DB Browser": It might be necessary to make a "Reset Layout" with a following restart to see it.
Wo kann ich "Reset Layout" machen? Finde das nicht.
Bei mir fehlt der "DB Browser" Reiter.
Schau mal hier (rechte Maustaste und RESET LAYOUT):
Danke!
FMDABDX
Beitrag von FMDABDX »
Clem01 hat geschrieben: So 7. Jan 2024, 20:39
FMDABDX hat geschrieben: So 7. Jan 2024, 20:21 I like to save my own lay out which is as attached but in "save layout as" only map question appears and cannot give a name.
How to save this lay out?
Also question why is transmitter location called "Name"? And why is this text not centered to the left?
- To save/restore the layout, you need to select an existing directory in the file dialog. The content of the layout needs a directory, as it consists of a number of files, see the "Persistence" folder.
- "Name" is the name of the transmitter location. That is the reason.
- All column header texts are centered.
By save layout only question to choose a map and no question for file name; the path /Persistence/Layout is empty.
HOL Sliedrecht
Clem01
Beitrag von Clem01 »
@FMDABDX
cgfan hat geschrieben: So 7. Jan 2024, 21:02
In the opened file save dialog you can do a right click in an empty area and chose "create a new folder" from the context menu.
Then you can select this newly created folder for saving the layout.
Please proceed in the way as posted by @cgfan. If you have problems, a screenshot would be necessary. In case you are suspecting a bug, the Issues are the right place to post it.
Dass Qirx bei Mausbewegungen oder im Browser den Sync verliert, ist ja bekannt, aber dass dadurch der SPI (der vorher geladen hat) nicht mehr eingelesen wird, ist mir erst jetzt aufgefallen.
Abhilfe: Kanalwechsel und zurück zum richtigen Kanal mit SPI.
Und noch etwas:
Ich habe die ganze Nacht hindurch Qirx auf dem slowenischen R2W Mux rennen gehabt. Die grünen Punkte leuchten noch immer, aber selbst nach 8 Stunden findet sich keine einzige Datei im Ordner.
AbracaDABra kann die Logos und den EPG aber sehr wohl einlesen.
Soll ich dir eine ETI-Datei hochladen?
Vielleicht hilft aber schon der angehängte Log.
qirx.logqirx.log-2024-02-01--00-13-31.txt.zip.changtozip.txt
gezippt, bitte Erweiterung ändern
(145.05 KiB) 11-mal heruntergeladen
Drehrumbum
Beitrag von Drehrumbum »
andimik hat geschrieben: Mi 31. Jan 2024, 21:53Dass Qirx bei Mausbewegungen oder im Browser den Sync verliert, ist ja bekannt
Kannst Du das bitte etwas erläutern?
Meint "im Browser" den Syncverlust z.B. durch das Öffnen von Firefox? Dagegen hilft das Hochsetzen der Priorität der rtltcp ganz gut. QIRX sollte sowieso auf "hoch" gestellt sein, denn QIRX hat es nunmal _sehr_ eilig. Kein Mensch weiß, welche Prozesse beim User sonst noch mit normaler Prio laufen (und auch etwas zu tun haben, also nicht auf Eingaben oder Daten von der Festplatte etc. warten). Da kann sich QIRX nicht in die "Normalo-Gruppe" einreihen und warten, "bis es mal wieder dran ist" (Round robin). Es muß "gleich wieder" (priorisiert) Rechenzeit bekommen, falls es nicht selbst auf Input warten muß. Aber das macht das OS schon. Wenn QIRX danach nix zu tun hat, kann das OS die übrige Rechenzeit (Zeitscheiben) gern weitergeben.
Aber "Mausbewegungen"? Da stehe ich jetzt auf dem Schlauch. Was sich massiv auswirkt, ist das Verschieben der Tiles, besonders wie im Bildchen markiert.
Die SymbolTime geht dabei richtig hoch, was ganz schnell zum Syncverlust führen kann. Selbst bei 2,7 GHz wird es knapp, wenn man die Maus länger so bewegt und die GUI reichlich zu tun hat.
BTW: Wegen dem "Mute" - ich finde es ganz praktisch, so wie es ist. Das automatische "Unmuting" nach einem Syncverlust (oder halt nach dem Umschalten auf ein anderes Programm) hat schon mehrfach geholfen, Fehler zu finden. Ab hier... viewtopic.php?p=1707363#p1707363
PathTweaker for QIRX-SDR: https://github.com/Drehrumbum/PathTweaker#pathtweaker
2300A
Beitrag von 2300A »
Ich habe die Version 4.2.1. Mit dem 12A-Mux habe ich das Problem, dass keine SPI-Daten eingelesen werden.
Bei allen anderen Muxen (5B, 5C, 5D, 8A und 9A) ist das kein Problem.
Es werden alle Logos in der Senderliste eingelesen. Außer beim 5B - "Radio T" und "Sachsen eins C" und beim 8A -"Radio T". Das muss aber (glaube ich) so sein.
Das mehrfache löschen des Ordners "SPI" mit nachfolgendem Neueinlesen ist regelmäßig bei den 5 Muxen erfolgreich. Beim 12A tut sich nichts.
Es wird ein Ordner "E01139" mit einem leeren xml-Ordner angelegt.
Im Ordner "SIdPool_E0" sind auch keine passenden Ordner (z.B. "1998") vorhanden. Ich denke aber diese Ordner legen sich erst an, wenn SPI-Daten eingelesen wurden.
Vor dem Löschen hatte ich noch Logos von RADIO TEDDY (1B2E), Schlager Radio (1735) und FEMOTION (1998). Da weiß ich aber nicht wann die eingelesen wurden (möglicherweise mit einer anderen Qirx-Version).
Was kann ich tun um das "Problem" zu beheben. :gruebel:
Standort: Chemnitz 380 m; 1,2 km nördlich von Chemnitz-Reichenhain; 21,9 km nördlich Chemnitz/Geyer
Das gleiche Problem hab ich in Slowenien auch (Ordner bleibt leer). Clem hat gemeint, die senden nicht Norm-konform, weil es nicht der Directory-Modus ist.
https://github.com/softsyst/qirx_issues/issues/143
Drehrumbum
Bitte langsam.
1.) Wir sind nicht in Slowenien
2.) Die MB "kann" selbstverständlich SPI, wie andere Muxe beweisen.
Es ist daher also schon einmal sehr naheliegend, dass der 12A Sachsen kein SPI sendet.
Stellt man QIRX auf 12A, schließt dann das Programm, löscht den SPI-Ordner und startet QIRX neu, passiert rein gar nichts im SPI-Ordner. Der Ordner "SPI/E01139" wird nur und erst von QIRX angelegt, wenn zuvor die SPI-Logos vom 5C komplett eingesammelt wurden. Dann enthält der "SPI/E01139" Ordner die Unterordner und SPI-Logos für Femotion, Schlagerradio und Radio Teddy, die allesamt aus der "5C-Logo-Sammlung" stammen und dann auch angezeigt werden.
Wenn in anderen Muxen SPI-Logos teilweise fehlen, wurden sie halt vom jeweiligen Veranstalter noch nicht hinterlegt.
EDIT: Radio Blau hat es im RegioMux Leipzig (10A) auch endlich geschafft SPI-Logos zu hinterlegen. Das muss relativ neu sein, würde ich jetzt mal behaupten.
2300A
Beitrag von 2300A »
Also ist mein "Problem" nicht lösbar. 12A sendet keine SPI-Daten, und die in 12A angezeigten Logos sind Beifang vom 5C.
Die drei Logos sind jetzt wieder da, da ich nun alle Muxe eingelesen habe.
Drehrumbum
Das Problem lässt sich im Moment nur teilweise lösen. Das sieht für den 12A und "händisch" gemacht so aus:
Die Logos stammen von der Media-Broadcast (https://www.media-broadcast.com/hoerfun ... o-service/) und können von den Empfängerherstellern genutzt werden. Im Prinzip könnte Clem diese Zipdatei auch anzapfen (so ähnlich wie beim Update der Senderdatenbank) und in den SidPool-Ordner integrieren. Die neuesten SPI-Logos in diesem Zip stammen vom "Rundfunkkombinat" vom 4.1.24.
cgfan
Beitrag von cgfan »
2300A hat geschrieben: Mi 21. Feb 2024, 18:56 12A sendet keine SPI-Daten
so sieht es aus, denn seit Version 4.0.6 gibt es einen Indikator, der in Bewegung ist, wenn das Datensammeln aktuell stattfindet:
Ohne SPI-Daten fehlt der Indikator:
Freundliche Grüße
cgfan
QTH: Magdeburg Stadtfeld Ost
2300A hat geschrieben: Mi 21. Feb 2024, 14:24 Ich habe die Version 4.2.1. Mit dem 12A-Mux habe ich das Problem, dass keine SPI-Daten eingelesen werden.[...]
Also ich habe auf fmscan geschaut, da gibt es offenbar keine SPI-Daten: :D
https://fmscan.org/net.php?r=d&m=s&itu= ... chsen+K12A
Zumindest war es gestern so.
Daher solltest du dich mit dem Betreiber in Verbindung setzen, falls es früher auf diesem Kanal schon geklappt hat.
Aber mit Qirx hat es aber wirklich nichts mehr zu tun.
2300A
Beitrag von 2300A »
@Drehrumbum
Danke für den Tipp. Nun sieht es bei mir auch so aus.
Stellt sich nun aber die Frage - Warum werden auf 12A keine SPI-Daten übertragen?
Wie verhält es sich beim vergleichbaren 11C in Sachsen-Anhalt?
@andimik
Du hast Recht. Es hat sich jetzt herausgestellt, dass es nicht an QIRX liegt. Aber irgendwo musste ich mit meiner Suche anfangen.
Nachdem ich nun dem Hinweis von @andimik gefolgt bin, gehe ich davon aus, dass der 11C auch keine SPI-Daten sendet.
cgfan
Beitrag von cgfan »
2300A hat geschrieben: Mi 21. Feb 2024, 22:05
Aktuell keine SPI-Daten:
Freundliche Grüße
cgfan
