Airspy HF+ Discovery Server. Online now.
MikeF
Beitrag von MikeF »
If anyone would like to have a play, my HF+ Discovery is online via SDR# SpyServer at sdr://92.4.75.197:5555 I'll leave it up for as long as I can but will probably be using it myself later. The Korner is beaming 190°.
Have fun!
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Receivers: * Sony XDR-F1HD (PC controlled via Seeeduino board & XDR-GTK software v.1.0) * Elad FDM-S2 SDR * Airspy HF+ Discovery * Airspy R2 SDR * Airspy Mini * SDR Play RSP1A *
Antenna: P.Körner designed 19.4 Yagi (with improved gain & F/B ratio) horizontal at 11m agl / 92m asl (http://www.ukdx.org.uk/fm/Korner%2019.4 ... 4_yagi.htm ) on a Tennamast 7.6m telescopic / tiltover mast
( http://www.ukdx.org.uk/fm/Tennamast.htm ) * GP cut for ~30MHz * TGN ULNA 3018 Mk.IV Band 2 masthead preamp * CCW Multicoupler feeding all tuners/SDRs 8 * Yaesu G1000DXC rotator *
Software: SDR# v1714 * SDR Console v3 * Elad FDM-SW2 v3.019 * RDS Spy v1.03 *
Propagation maps produced by FMLIST http://www.fmlist.org/ul_login.php?sprache=en
Propagation Maps and TX sites logged for the Month maps at
http://www.ukdx.org.uk/fm/FMLogs/Prop%2 ... 20Maps.htm
All-time FM log (from 2003) and current month's log at http://www.ukdx.org.uk/fm/FMLogs/FMLogs_index.htm
All-time Meteor Scatter Log map at http://www.ukdx.org.uk/fm/MSMap.htm
YouTube Channel: http://www.youtube.com/c/MikeFallonSussexFMDX
FMDABDX
Re: Airspy HF+ Discovery Server. Online now.
Beitrag von FMDABDX »
MikeF hat geschrieben: Sa 31. Aug 2019, 11:01 If anyone would like to have a play, my HF+ Discovery is online via SDR# SpyServer at sdr://92.4.75.197:5555 I'll leave it up for as long as I can but will probably be using it myself later. The Korner is beaming 190°.
Have fun!
Nice Mike
After quick scan 87.7 and 90.9 Spain
Ruud
HOL Sliedrecht
ullibg
Beitrag von ullibg »
I will try it also if you are again online!
ullibg
Thanks Mike!!! :spos: :cheers:
Just heard on 91.2 Mhz Spain :)
MikeF
Beitrag von MikeF »
Thanks all. Glad you're enjoying it. I'll leave it running overnight, at least to early morning anyway. Now beaming 90°
Mike
ullibg
Good morning Mike heard some german stations
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
The Airspy HF+ Discovery work's verry well! Thanks that we can try the SDR! :spos: :cheers:
MikeF
Beitrag von MikeF »
ullibg hat geschrieben: So 1. Sep 2019, 07:44 Good morning Mike heard some german stations
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
Thanks Ulli. Yes I'm very impressed with the Discovery. I'll leave the server up for now until I need to use it. Now beaming 120°.
MikeF
Beitrag von MikeF »
I'll leave the server running overnight. Beaming 150
Mike
ullibg
Mike, are the French Stations ever so strong like now? How far is the French Coast from your Location?
Best Greatings
Ulli
MikeF
Beitrag von MikeF »
ullibg hat geschrieben: Mo 2. Sep 2019, 22:06 Mike, are the French Stations ever so strong like now? How far is the French Coast from your Location?
Best Greatings
Ulli
Yes, the French stations are always that strong. Yesterday's conditions were flat but when there is a lift they are even stronger! The nearest point on the French coast is around 110km from here. Dieppe is 125km and Paris 270 km.
ullibg
I ask you, because some of them are strong like a local station.
MikeF
Beitrag von MikeF »
I'll leave the server up for a while. Lots of German stations coming in now. Beaming 80. Try using a narrow bandwidth (~80kHz) and tune slowly up/down the band.
Mike
ullibg
Hello Mike, does the peaks above 100Mhz come from a switching power supply?
MikeF
Beitrag von MikeF »
ullibg hat geschrieben: Sa 7. Sep 2019, 07:38 Hello Mike, does the peaks above 100Mhz come from a switching power supply?
Hi Ulli, yes they do. It's a new AIS receiver. I'll be changing the PSU as soon as possible
Mike
MikeF
Beitrag von MikeF »
Airspy Discovery is back online now. Lots of very good German and Swiss tropo about. sdr://92.4.75.197:5555
Have fun
Mike
