Is it normal this ?
If I set -RTLTCP, it shouldn't look for an USB device.
You need to install the required Realtek DLLs, this can be done by installing the driver "Treiber 1": https://www.ukwtv.de/cms/index.php?opti ... eiber1.zip
Best regards,
Andi
Standort: München-Bogenhausen
But the SDR Device is not plugged in Computer, is on Enigma2 sat receiver.
I think that in that particular case, program should not look for driver.
The driver (which also installs a couple of required DLL files) always needs to be installed in order for DAB Player to work.
Best regards,
Andi
OK. Thank's.
I've installed it (driver 2, because it's a RTL-SDR v3 R820T Dongle), and I see one thing which is not working using RTL_TCP. ==> Automatic Gain control.
Other programs (Welle.io f.i.) do it.
and DAB signal works.
But on DAB_Player….
If I previously open another program which gives RTL server a gain value, then DAB_Player Works too.
root@et10000:~# rtl_tcp -a 192.168.0.16 -p 1234 -s 2048000 -P 10
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Tuner error set to 10 ppm.
[R82XX] PLL not locked!
Tuned to 100000000 Hz.
listening...
Use the device argument 'rtl_tcp=192.168.0.16:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...).
client accepted!
set gain mode 1
set gain 0
set freq 195936000
set sample rate 2048000
set gain 8
set gain 13
set gain 27
set gain 37
set gain 76
set gain 86
set gain 125
set gain 143
set gain 156
set gain 166
set gain 197
set gain 207
set gain 228
But on DAB_Player….
Found 1 device(s):
listening...
client accepted!
set freq 195936000
Hallo @Andi_Bayern ist das gewollt oder ein Bug in der neusten Wine Version mit Withlog das der zuletzt gespielte Sender nicht gespeichert bleibt nach dem neuen Starten immer beim Schwarzwaldradio anfängt? Ich bin der Meinung das war früher in den älteren Versionen nicht. Ist ja nicht schlimm aber eventuell eine Überarbeitung wert?
Hi, I'm new at this forum
On one of the channels in a local mux here in Denmark, we have begun to show news headlines as DLS, and mark them up as "Local news" (code 13, INFO.NEWS.LOCAL) in DL+.
But I have not been able to view them as DL+ in DAB Player. I also tried with code 12, INFO.NEWS, but they are still not shown. But if I change the code to for example 29, INFO.URL, they are shown.
If I try with the original software for Noxon DAB USB-stick, both INFO.NEWS and INFO.NEWS.LOCAL are shown, and they are also shown on a domestic receiver here. But DAB Player does not show them.
Are we doing something wrong, or does DAB Player just not support these DL+ content types? Can you confirm or unconfirm that the DL+ codes 12 INFO.NEWS and 13 INFO.NEWS.LOCAL should be shown?
Thank you,
Ulrik
Thank you,
Ulrik
These DL+ tags are not supported.
Only the following are supported:
ItemTitle (1)
ItemAlbum (2)
ItemArtist (4)
ItemComposer (8)
ItemBand (9)
InfoDate_Time (24)
InfoAdvertisement (28)
InfoUrl (29)
StationnameShort (31)
StationnameLong (32)
ProgrammeNow (33)
ProgrammeNext (34)
ProgrammeHomepage (39)
PhoneHotline (41)
PhoneStudio (42)
SmsStudio (44)
EmailHotline (46)
EmailStudio (47)
EmailOther (48)
Best regards,
Andi
Sorry Text lies sich nicht mehr bearbeiten.
Hallo @Andi_Bayern ist das gewollt oder ein Bug in der neusten Wine Dab Player Version mit Withlog? Also das der zuletzt gespielte Sender nicht gespeichert bleibt und nach dem erneuten Starten immer beim Schwarzwaldradio anfängt? Hört man Beispielsweise auch den NDR fängt der Player immer im Bundesmux wieder an zu Spielen. Ich bin der Meinung das war früher in den älteren Versionen nicht. Ist ja nicht schlimm aber eventuell eine Überarbeitung wert?
Thank you Andi, that explains why.Andi_Bayern hat geschrieben: ↑Fr 16. Aug 2019, 09:25These DL+ tags are not supported.
Is there any chance of code 12 and 13 being supported in 1.0.2.155? *Fingers crossed*
Best regards,
Ulrik.
Wenn das Programm sauber beendet wird (ohne Absturz) dann wird der zuletzt gehörte Sender auf jeden Fall gespeichert.Das muß Kesseln hat geschrieben: ↑Fr 16. Aug 2019, 09:43...
Viele Grüße,
Andi
Danke @Andi_Bayern das ist immer so eine Sache den Player sauber zu beenden unter Linux. So läuft der aber ganz Stabil.
Just a thought:Andi_Bayern hat geschrieben: ↑Sa 17. Aug 2019, 17:12Wenn das Programm sauber beendet wird (ohne Absturz) dann wird der zuletzt gehörte Sender auf jeden Fall gespeichert.Das muß Kesseln hat geschrieben: ↑Fr 16. Aug 2019, 09:43...
Perhaps this issue could be related to missing user write permissions? I'm not familiar with Wine, but in general Linux is very picky about user permissions.
If for example the software was installed with super user (root) privileges, but is running as a standard user, it might not have the necessary permissions to store the information of last played station. @Das muß Kesseln you can double check that the user, under which the software is running, has write permissions to the folder where this information is stored (@Andi_Bayern, which folder is it?).
By the way, @Andi_Bayern, now that this subject is up, I have noticed a possible small bug:
I'm running 1.0.2.154 in Windows 10, and automatic select of the last played station at startup works fine for me. But if the last played station no longer exists in the mux, the software will hang at startup. In this case, the only way out seems to be to unplug the antenna before startup (so that the mux is not received), then start the software, select another station and then plug the antenna back in.
Best regards,
Ulrik.
Übersetzt mit dem Googel Übersetzer. Hello I have installed the Dab player under PlayonLinux and there created a new folder. Thank you for the thought kick.@Das muss Kesseln Sie können überprüfen, ob der Benutzer, unter dem die Software ausgeführt wird, Schreibberechtigungen für den Ordner hat, in dem diese Informationen gespeichert sind
DAB Player unter Ubuntu 18 64-Bit
Hallo, gibt es irgendwo eine Anleitung, wie man den DABplayer unter Ubuntu 18 64-bit zum Laufen bekommt? Ich konnte den realtek-Treiber und die beiden vc-redistributables installieren, aber beim Starten des DABplayer erhalte ich immer die Meldung "Es ist keine Verbindung zu rtl_tcp an 127.0.0.1:1234 möglich!" Die Forensuche nach "rtl_tcp" ist leider nicht möglich...
Danke!
Danke!
