Radioforum Österreich
UK-DX
Re: oe24 / Radio Austria: Zweites bundesweites Privatradio in Österreich startet
Beitrag von UK-DX »
I like radio hat geschrieben: Sa 12. Aug 2023, 16:08 I dont want to be off-topic in this thread, so a brief and last commnent. I dont think Austria is the sick man of Europe with regard to Radio broadcasting (except the ORF anomaly), you passed a "6 stations bill" and another DAB tender in the pipeline. There may be other candidates to hold "sick man" title, maybe Spain.
Yes, UK is a different story, that momentum of small-scale DAB launch...wow..no wonder, to use your terminology, UK is the healthy music man of Europe :)
Regarding radio broadcasting if you ever lived in the UK or Ireland and are used to this kind of market and business environment, you'll sure find Austria a very strange, even backwards oriented place.
One oddity about Radio Austria is that once they are officially granted the permanent use of a certain FM frequency they tend to use it temporarily, only to shut it down again a couple of months later. The reason for this is beyond my understanding and defies all logic. I am often inclined to think that they are not really serious about business. Also their website is often out of date, they are mentioning frequencies being on air, but in reality they are not.
It is rumoured that Radio Austria will be sold at some point, quite possibly to a foreign media organization or some other investor. I often have personal doubts about this as well, as I don't think that the weak FM frequencies and the limiting coverage across Austria would ever make enough profit to any potential investor to be of interest.
ertsch
Beitrag von ertsch »
Die Sendeanlage Aspang 2 kulmariegel 102,5 Radio Austria ist seit über einer Woche ausser Betrieb.
Und die Gleichwelle 102,5 funktioniert auch auf der A2 nicht gut von wr. Neustadt nach Aspang. Störungen und kraspln im Ton.
Über Dab+ ist Top Empfang von Radio Austria.
Harry41
Beitrag von Harry41 »
ertsch hat geschrieben: Di 15. Aug 2023, 12:17 Die Sendeanlage Aspang 2 kulmariegel 102,5 Radio Austria ist seit über einer Woche ausser Betrieb.
Irgendwie müssen sich die Nachteile eines FM Radios gegenüber dem DAB+ auch langsam bemerkbar machen.
Harry41
Wenn man dem Herrn Fellner kein gscheides FM Material liefert ,wie soll er dann gscheides Programm machen auf FM.
ertsch
Ich höre täglich "Radio Austria" über Dab+ im Auto.
Das geht bei mir in Aspang und nach Wr. Neustadt in die Fahrt zur Arbeit auch sehr gut.
Einziger Nachteil bei Dab+ sind dicke mauern und LED Beleuchtung.
Harry41
ertsch hat geschrieben: Di 15. Aug 2023, 14:34 Ich höre täglich "Radio Austria" über Dab+ im Auto.
Zwar laufen auf R.Austria nicht soviele Titeln wie bei manch anderen Programmen,aber dafür sind die gespielten Songs in Ordnung. Außerdem finde ich eine kleine Radiofamilie für bedeutend interessanter,da werden auch Hörerwünsche immer wieder erfüllt.Aus dem 20 km entfernten Klagenfurt ist das FM Signal nur recht schwach aufzunehmen,in DAB+ funktioniert das schon besser.
UK-DX
Beitrag von UK-DX »
Harry41 hat geschrieben: Di 15. Aug 2023, 13:43
Beides wird in Oesterreich leider sehr falsch gemacht.
DAB+ kommt in Oesterreich nicht ueber die derzeitigen 15 Sender hinaus, - weitaus zu wenig um DAB+ jemals erfolgreich als "in ganz Oesterreich" zu vermarkten. Der Bundesmux in Oesterreich muesste mindestens 25 bis 30 Sender haben, um das Land wirklich abzudecken, und dies waere erst einmal ein Grundnetz.
Bei UKW laeuft bei Radio Austria dann immer das gleiche Spiel, kaum ist eine Frequenz zugewiesen und in Betrieb wird sie wieder irgendwann abgedreht. So fehlt dzt. die Gleichwelle in Feldkrich, und Sender in Reutte, auch in Mayrhofen bzw. Zell am Ziller sowie Lienz in Osttirol. Offenbar bekommt man die Gleichwelle auf 102,5 auch nicht so richtig hin und wer weis ob jemals die 102,5 in Rechnitz auf Sendung geht, und ob das ueberhaupt sinnvoll ist.
Will Radio Austria ganz Oesterreich wirklich serioes ueber UKW abdecken, muss man da mit mehr Dampf rangehen. D.h. aktiv und eigeninitiativ neue Frequenzen suchen bzw. in Auftrag geben lassen, beschraenkt ausschreiben und rasch in Betrieb nehmen. Dies sollte wenn moeglich ohne langes Rechtsverfahren gehen. An eine gleiche Abdeckung wie etwa KroneHIt wird man aber wahrscheinlich dennoch nicht kommen.
Selbst wenn Radio Austria verkauft werden soll, - bei solchen bisherigen Praktiken schreckt jeder potentielle und serioese Kaeufer ab.
Haette Classic FM in UK, oder eben in Irland Today FM ( vormals Radio Ireland ) oder Newstalk so angefangen, waere dies bestimmt nichts geworden.
Für einen potenziellen Käufer ist das doch egal. Für den zählt, was er für das Geld auf dem Papier an UKW-Senderkette bekommt, und danach kann er ja so weiter ausbauen (lassen) wie es ihm gefällt. Und wenn er mit der Vorgeschichte von Radio Austria ein Problem hat, muss er halt einen Relaunch unter neuem Namen machen.
Ich denke, Fellner hatte vielleicht von vornherein das Ziel, die wertvolle 2. bundesweite UKW-Lizenz gewinnbringend zu verkaufen, das erklärt dann auch die Sparmaßnahmen beim Programm und der technischen Verbreitung und diverse halbherzige Entscheidungen.
Aber erst mal schauen, ob er die Radio Austria -Lizenz dann auch zu seinen Wunschkonditionen los bekommt und wenn ja, wer dann der Käufer sein wird.
Eure positiven Erfahrungen mit DAB+ in Ehren, das Problem ist der Otto-Normal-Hörer und nicht wir DXer. Wenn real nur 10% DAB+ nutzen, aber 100% UKW, bringt dir die beste DAB+Abdeckung auch nicht so viel.
Wenn denn mal DAB-only-Programme wie Radio Flamingo im Radiotest mit relevanter Quote auftauchen, werden die Programmanbieter langsam umdenken. Aber derzeit sind diese Programme alle praktisch noch nicht relevant für Werbetreibende, trotz technischer DAB+Abdeckung von weit über 80%.
Selbst in Deutschland, wo sich DAB+ schon deutlich stärker durchgesetzt hat, wüsste ich noch von keinem profitablen DAB+only Programm.
Momentan bleibt einem Programmanbieter nichts übrig, als zweigleisig zu fahren.
Die derzeit laufende Ausschreibung eines weiteren bundesweiten Multiplexes und von Regionalmuxen könnte da durchaus was verändern, aber das wird noch dauern.
Bis dahin ist tatsächlich noch UKW das Maẞ der Dinge...
UK-DX
Beitrag von UK-DX »
DAB brachte in UK so einige Sender wieder in den Radiomarkt, die verschwunden waren und vermisst wurden. Etwa Jazz FM, oder auch Virgin Radio, und einige wie Kiss, Capital, Heart oder Smooth konnten ihr Sendegebiet deutlich erweitern.
Ich frage mich, wie lange TalkSport noch auf MW sein wird, und dann nur noch auf DAB sein wird? Der Sprung von MW auf DAB wird ja ein grosser sein, was Einsparung der Sendekosten betrifft. Bei Absolute 1215 war dies ja das gleiche Thema.
Wer neu ist, muss sich erst einmal durchsetzen, und zeigen, etwas zu koennen. Aktuell sehe ich das bei Radio Austria kaum, weder von den Nachrichten, dem Verkehrsfunk noch dem lueckenhaften Sendernetz, egal ob UKW oder DAB+.
Jeder potenzielle Kaeufer wird wissen, dass DAB+ in Oesterreich kaum etabliert ist, damit keine nennenswerten Geschaeftszahlen produzieren kann, und er ueber UKW kaum an gute Frequenzen kommt. Lange Antragstellungen, Genehmigungen und folgende Rechtsstreitigkeiten ueber die wenigen verfuegbaren UKW Frequenzen von anderen Anbietern ziehen alles lange Zeit dahin, und lassen zwischenzeitlich jeglichen Erfolg ausbleiben. Und dann mischt die Politik auch noch immer gerne im Radio mit hinein. Dies alles schreckt halt Jeden ab. Oder man nutzt dies um einen besseren Preis herauszuhandeln.
Wenn man den Zeitablauf betrachtet ist dies ja schon gruselig. Von Rechnitz bis Graz einen durchgehenden Empfang zu bekommen, bis hin, dass die 102,5 dort mit der 102,4 herumkaempft, und es bis heute noch keinen wirklichen Plan gibt, wie man es sich vorstellt die Strecke von Graz bis Klagenfurt abzudecken ist ja schon mehr als geschaefts- und profitfremd. Wir reden hier schaetzungsweise von weiteren 5 Jahren um die notwendigen UKW Frequenzen zu bekommen, und dies, sollte es ueberhaupt so weit sein.
Da ist es fuer Bauer eine weitaus leichtere Entscheidung in Irland einzukaufen.
Wann wurde das DAB+ Netz in Oesterreich zum letzten Mal erweitert? Ich glaube die 15 jaemmerliche Sender waren ja schon mehr als lange. Ofiziellen Plan dieses Netz zu erweitern kenne ich nicht, ein Datum wird oder wurde auch nie genannt? Bzw. laesst sich hier nichts finden.
Oder stelle Dir vor, Du willst ein Mobilfunknetz anbieten, hast aber solche Luecken und auch keinen oeffentlich wahrnehmbaren Plan diese jemals zu schliessen. Da nimmt Dich keiner mehr Ernst.
UK-DX hat geschrieben: Di 15. Aug 2023, 20:35 Wann wurde das DAB+ Netz in Oesterreich zum letzten Mal erweitert? Ich glaube die 15 jaemmerliche Sender waren ja schon mehr als lange. Ofiziellen Plan dieses Netz zu erweitern kenne ich nicht, ein Datum wird oder wurde auch nie genannt? Bzw. laesst sich hier nichts finden.
Irgendwer muss das bezahlen. Wenn eine Mehrheit der Programmanbieter entscheidet, dass der derzeitige Zustand ausreichend ist und man vorerst nicht mehr Geld investieren möchte, weil man diese Investitionen derzeit nicht wieder rein bekommt, dann ist das leider so.
Selbst wenn ein paar dabei wären, die gerne mehr ausbauen würden, hilft es nix, wenn die Mehrheit der Programmanbieter das nicht will. Das ist die Krux dieser Multiplexe.
Nimm mal alternativ Radio 88.6 als Beispiel. Die sind über DAB+ bundesweit empfangbar. Aber wo erreichen sie nennenswerte Quoten? Im UKW-Sendegebiet. Und du wirst sehen, dass die neuen UKW-Funzeln in Graz und Oberösterreich sich deutlich im Radiotest niederschlagen werden, obwohl sie dort schon jahrelang über DAB+ zu hören waren und damit doch auch schon früher Quote hätten machen können.
I like radio
Beitrag von I like radio »
UK-DX hat geschrieben: Di 15. Aug 2023, 10:02
One oddity about Radio Austria is that once they are officially granted the permanent use of a certain FM frequency....
bizzare situations can probably be seen worldwide, an interesting schyzophrenia this Radio Austria striving nationwide FM and simultaneously kicking-off on DAB; who knows, they may know what they are after...by the way I tuned them tonight on DAB 5D and was stunned by "Manfred Mann - Ha! Ha! Said The Clown (1967)", jesus, when the hell have I heard it last time?!
There may be a problem with the radio market in small countries, commercial stations want to make a profit and money inflow is limited (advertisements). In the past the market on FM reached a skewed equilibrium - limited access to FM frequencies and money distribution among established players. Whether profits fair, in excess of fairness or low...I do not know, Im not a radio market expert.
But for sure, DAB, besides bringing new opportunities will probably bring a new equilibrium, diluting money among more players...and this is what current privileged "eternal" FM players oppose...sometimes through a histeria pushed via crystal clear politicians and law makers :)
However, for small markets there is that damned devil in the form of simulcast broadcasting costs. Whatever the solution, bureaucracy in any form has to be ousted out in this process.
Let people decide. If people want to listen to the radio via air, let them decide. Feeling of the people is decisive. See US decision to go on with AM in car radios - probably the people want it.
UK-DX
Beitrag von UK-DX »
I like radio hat geschrieben: Di 15. Aug 2023, 23:42
The thing is, Radio Austria's strategy, or more lack of it, is difficult to understand even at the best of times. Maybe they have financial issues, thus even a 100 watt transmitter is too expensive for them? No idea. I often doubt that any foreign investor or foreign media organization would seriously be interested in entering the Austrian market, but again, I could also be wrong. You're in Brno correct? It surprises me that you can pick up 5D from Vienna? Can you actually receive 102.5 in Brno? Apparently 102,4 is coordinated in Brno, but never went on air?
I think the biggest threat to the existence of radio in the future is the large abundance of cell phones. Everyone has one these days, and not even one, but often two, at least in the UK. They all have either flat rates or a high data volume per month allowing anybody to listen to anything they like. Most of today's FM stations offer live streams on the internet, something anybody can listen to, as long as they have a smart phone. The generation below 35 in the UK doesn't even know how to tune an FM radio, but knows how to install any app on a smart phone, - at least that's my impression. With data roaming charges abolished across Europe there are no issues any more, if one is travelling, except of course “glorious Brexit-UK”.
The Czech republic isn't exactly a large country either but has a rather lively radio market, considering that it was once communist. - Slovakia is a similar example. Other small countries like Belgium, the Netherlands, Norway and Switzerland have successfully implemented DAB+, so I guess it 's more a matter of promotion and marketing than anything else.
In the Republic of Ireland there is strong resistance regarding DAB, the independent local radio stations are strongly opposed as well, whilst NI has full DAB coverage, BBC as well as commercial. Belfast has 4 DAB multiplexes on air as far as I know and the local commercial stations are still doing fine. DAB overspill from NI to the Republic is limited, except county Cavan and Dundalk.
I like radio
UK-DX hat geschrieben: Mi 16. Aug 2023, 00:32
I think the biggest threat to the existence of radio in the future is the large abundance of cell phones.... The generation below 35 in the UK doesn't even know how to tune an FM radio...
The Czech republic isn't exactly a large country either but has a rather lively radio market...
To be in line with this thread a brief comment on Radio Austria on FM.
yes, I live in Brno. I am not interested in FM reception, so tried 102.5 MHz to give you a feedback, in the eastern part of city I tuned it today on a hand-held radio with telescope antenna outdoors - no noise, but only mono, after some time their logo -AUSTRIA appeared (10kW from Kahlenberg not sufficient).
That 102,4 in Brno is an interesting question, its not active and I do not know if ever was, I googled a bit and found a local info that Dance Radio wanted to use it (if used or not do not know), but their competitor, Free Radio took it to court and finally won and then they returned the licence to the regulatory authority. Rumours explained that just wanted to block their competitor :)
It suprises me that it suprises you I receive 5D from Austria :) 5D SFN is robust, it can be received here with a hand-held radio in any place that is not too blocked southward. At home I use an external antenna with pre-amp and 5D is in a very very safe C/N region and stable 24/7/365. SDR QIRX showed me 5 transmitters contributing: Kahlenberg, DC-Tower, Liesing, Jauerling and Semmering, the first one being the strongest.
I safely receive also 11C CityMUX Wien II, although I have to use band stop filter for the Czech 12D, because I live nearby the transmitter which raises the noise level for neighouring channels.
I am surpised by your pesimism about radio listening in UK. Latest Q2 survey by RAJAR shows: 40% DAB, 31% AM/FM, 14% Smart speakers, 10% Website/Apps and 4% DTV. One or two years ago I registered a comment that DAB listening is age-indenpendent.
Czech Republic "has a rather lively radio market". Not so straightforward, do not forget about the realm of "dudeln musik" :)
UK-DX
Beitrag von UK-DX »
I like radio hat geschrieben: Mi 16. Aug 2023, 20:35
I've read it somewhere, not sure, when and where, that there was an application to use 102,4 in Brno, but that never came to fruition. Don't know if there were any objections from Radio Austria or any other authority? Don't have that insight at all.
I like radio hat geschrieben: Mi 16. Aug 2023, 20:35 It suprises me that it suprises you I receive 5D from Austria :) 5D SFN is robust, it can be received here with a hand-held radio in any place that is not too blocked southward. At home I use an external antenna with pre-amp and 5D is in a very very safe C/N region and stable 24/7/365. SDR QIRX showed me 5 transmitters contributing: Kahlenberg, DC-Tower, Liesing, Jauerling and Semmering, the first one being the strongest.
If you're receiving 5D from Austria with ease, I'd say congrats on that one. The downside of DAB and DAB+ is that it depends very much on the radio and the manufacturer regarding sensitivity and reception.
I have a Sony and the last time I was in Znoimo I barely received 5D from Austria and with 11C the only luck I've had was that the radio would show the identification of the stations but wouldn't play them. That was in 2021. Panasonic radios seem to be even worse, - don't know why. Possibly different chips, different sensitivity, etc...
DX reception with DAB and DAB+ is simply different and often unexpected as well. All along the South coast of Ireland, between Cork and Wexford one can often receive BBC on DAB whilst FM doesn't seem to make it? However in the Wicklow mountains one can pick up BBC Radio from Wales with ease but not DAB. Don't know why either.
That's not what I've meant. Don't get me wrong, DAB is firmly established in the UK by now. It's just that the younger generation doesn't seem to bother with radio at all any more, - neither FM nor DAB. They stream a lot more online, smart phones and bluetooth speakers seem to be the top choice.
I like radio hat geschrieben: Mi 16. Aug 2023, 20:35 Czech Republic "has a rather lively radio market". Not so straightforward, do not forget about the realm of "dudeln musik" :)
Back in the days, when Czech commercial radio went on air first, they all seemed to have had some good consultancy work from various other countries. A good friend of mine from Ireland worked for KissFM 98.1 in Prague for a couple of years. That was in the early 90ies.
I like radio
UK-DX hat geschrieben: Mi 16. Aug 2023, 00:32 Can you actually receive 102.5 in Brno?
to keep the topic of this thread I made another "exploration" of the Radio Austria 102.5 FM reception in Brno in a company car that has an excelent FM reception.
Driving on die :) Autobahn west-east a mixed result experienced, changing from very poor to poor to average to quite good to good. Good in the eastern part of the city and this fact conforms to my reception experience at my home which although 5 km away but in the same south-north sector. To sum up, no guaranteed happiness for everyone who would like to be happy with Radio Austria on FM :)
The last signal record I detected about 25 km away from Brno in the east-north direction on die Autobahn.
