New TEF Webserver
MikeF
New TEF Webserver
Beitrag von MikeF »
Hi All, I have now got a TEF 6686 webserver running at https://saltdean.fmtuner.org/ . Please have a play and let me know what you think.
I have WDR2 from Bonn coming in via scatter on 100.4 at the moment
Regards and Happy Easter,
Mike
RZCH
Re: New TEF Webserver
Beitrag von RZCH »
Hi Mike, very good!
To reduce the audio noise, I would enable the option to turn off the screen when XDR-GTK connection is active. Should be somewhere in the TEF settings.
You can also turn up the volume of the TEF.
Empfänger: SDRplay RSP1A | Mini Aluminium TEF6686 | RTL-SDR Blog V3
Antenne: UKW-Dipol im Balkon
YouTube
MikeF
Beitrag von MikeF »
RZCH hat geschrieben: So 20. Apr 2025, 13:24 Hi Mike, very good!
Hi, thanks.
I am not using GTK, just a desktop TEF into my PC, USB and audio.
I have a headless TEF arriving in a week or so , hopefully that will eliminate the noise
RZCH
Beitrag von RZCH »
MikeF hat geschrieben: So 20. Apr 2025, 13:46 Hi, thanks.
The option is in the TEF menu, and since the webserver uses the same protocol as XDR-GTK, it will also work with the webserver.
YouTube
alex
Beitrag von alex »
MikeF hat geschrieben: So 20. Apr 2025, 10:42 Hi All, I have now got a TEF 6686 webserver running at https://saltdean.fmtuner.org/ . Please have a play and let me know what you think.
Mike
Hi Mike,
many thanks for setting up and operating that web receiver.
Could play with it all day along.
Best regards
Alex
Empfänger: TEF6866 mit beiliegender Teleskopantenne
MikeF
Beitrag von MikeF »
alex hat geschrieben: Sa 26. Apr 2025, 08:56
Mike
Hi Mike,
Best regards
Alex
Thanks Alex, glad you are enjoying it. If you need the antenna to be turned, and I am available, just let me know.
Kind regards,
Mike
Htack
Beitrag von Htack »
Great, many thanks for making the server available. I will definitely spend some time, testing it in detail the next days. :danke:
Htack
Beitrag von Htack »
Currently the server seems to be offline.
MikeF
Beitrag von MikeF »
Htack hat geschrieben: Mo 28. Apr 2025, 20:54 Currently the server seems to be offline.
Yes, I've been changing over to a headless TEF 6687. All up and running since this morning :)
palis
Beitrag von palis »
Successful 1st May and month.In some frequencies on the server German programmes,mostly not distinguishing-a little bit better on 98.7
Standort: Neu-Ulm
Empfänger: Deepelec DP-666(mit eigener Antenne)
palis
Beitrag von palis »
88.8 pretty clear(und seine Lippen flüsterten…)
Standort: Neu-Ulm
palis
Beitrag von palis »
88.8 WDR5 Bielefeld
Standort: Neu-Ulm
palis
Beitrag von palis »
106.7 WDR 1live Langenberg/Hordtberg
Standort: Neu-Ulm
palis
Beitrag von palis »
101.3 WDR4 Langenberg/Hordtberg
(88.8 same location)
Standort: Neu-Ulm
palis
Beitrag von palis »
Brighton-Bielefeld ca 618km
Standort: Neu-Ulm
