My SDR# SpyServer
MikeF
My SDR# SpyServer
Beitrag von MikeF »
Hi,
Can anyone please try connecting to, and tuning, my SpyServer at sdr://94.196.41.239:5555 ? I have had a report that it's not functioning as it should.
Many thanks
Mike Fallon
MikeF
Re: My SDR# SpyServer
Beitrag von MikeF »
MikeF hat geschrieben: Mi 31. Mai 2023, 12:04 Hi,
Many thanks
Mike Fallon
Ullibg,
I had an email to inform me that you had replied to my message but I can't see it anywhere.
Thanks
Mike
ullibg
Beitrag von ullibg »
Hi Mike, I did a quick test earlier and it worked so I posted it.
But after testing it for a bit longer, I realized that wasn't the case.
But unfortunately I had to leave the house again.
That's why I deleted it again. The visible bandwidth is 660kHz and you were partially trapped in it. You could not change the frequency above or below this range. Whatever the reason, it seems to be working again!!???
ullibg
Oh crap, after I wrote it, it got stuck again.
Then I restarted SDR#, then it worked again. ???
MikeF
Beitrag von MikeF »
OK Ulli, many thanks for the feedback.
Mike
ullibg
:cheers:
