Airspy HF+ Discovery Server. Online now.
MikeF
Beitrag von MikeF » Sa 31. Aug 2019, 11:01
If anyone would like to have a play, my HF+ Discovery is online via SDR# SpyServer at sdr://92.4.75.197:5555 I'll leave it up for as long as I can but will probably be using it myself later. The Korner is beaming 190°.
Have fun!
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Receivers: * Sony XDR-F1HD (PC controlled via Seeeduino board & XDR-GTK software v.1.0) * Elad FDM-S2 SDR * Airspy HF+ Discovery * Airspy R2 SDR * Airspy Mini * SDR Play RSP1A *
Antenna: P.Körner designed 19.4 Yagi (with improved gain & F/B ratio) horizontal at 11m agl / 92m asl (http://www.ukdx.org.uk/fm/Korner%2019.4 ... 4_yagi.htm ) on a Tennamast 7.6m telescopic / tiltover mast
( http://www.ukdx.org.uk/fm/Tennamast.htm ) * GP cut for ~30MHz * TGN ULNA 3018 Mk.IV Band 2 masthead preamp * CCW Multicoupler feeding all tuners/SDRs 8 * Yaesu G1000DXC rotator *
Software: SDR# v1714 * SDR Console v3 * Elad FDM-SW2 v3.019 * RDS Spy v1.03 *
Propagation maps produced by FMLIST http://www.fmlist.org/ul_login.php?sprache=en
Propagation Maps and TX sites logged for the Month maps at
http://www.ukdx.org.uk/fm/FMLogs/Prop%2 ... 20Maps.htm
All-time FM log (from 2003) and current month's log at http://www.ukdx.org.uk/fm/FMLogs/FMLogs_index.htm
All-time Meteor Scatter Log map at http://www.ukdx.org.uk/fm/MSMap.htm
YouTube Channel: http://www.youtube.com/c/MikeFallonSussexFMDX
FMDABDX
Re: Airspy HF+ Discovery Server. Online now.
Beitrag von FMDABDX » Sa 31. Aug 2019, 12:12
MikeF hat geschrieben:
Have fun!
Nice Mike
After quick scan 87.7 and 90.9 Spain
Ruud
HOL Sliedrecht
4°46'00"E / 51°49'39"N
ullibg
Beitrag von ullibg » Sa 31. Aug 2019, 12:32
I will try it also if you are again online!
UKW-FM PORTABEL: Blaupunkt Panda CC (SHARX),Hyundai i10 Autoradio(Serie), 9-ELE. Eigenbau nach P.Körner, 9.2 nach Körner von Antennenland
ullibg
Beitrag von ullibg » Sa 31. Aug 2019, 12:56
Thanks Mike!!! :spos: :cheers:
Just heard on 91.2 Mhz Spain :)
MikeF
Beitrag von MikeF » Sa 31. Aug 2019, 21:42
Thanks all. Glad you're enjoying it. I'll leave it running overnight, at least to early morning anyway. Now beaming 90°
Mike
ullibg
Beitrag von ullibg » So 1. Sep 2019, 07:44
Good morning Mike heard some german stations
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
The Airspy HF+ Discovery work's verry well! Thanks that we can try the SDR! :spos: :cheers:
MikeF
Beitrag von MikeF » So 1. Sep 2019, 09:50
ullibg hat geschrieben:
88.0 WDR 5,Bonn
91.6 SWR3,Koblenz
Thanks Ulli. Yes I'm very impressed with the Discovery. I'll leave the server up for now until I need to use it. Now beaming 120°.
MikeF
Beitrag von MikeF » Mo 2. Sep 2019, 21:20
I'll leave the server running overnight. Beaming 150
Mike
ullibg
Beitrag von ullibg » Mo 2. Sep 2019, 22:06
Mike, are the French Stations ever so strong like now? How far is the French Coast from your Location?
Best Greatings
Ulli
MikeF
Beitrag von MikeF » Di 3. Sep 2019, 04:37
Best Greatings
Ulli
Yes, the French stations are always that strong. Yesterday's conditions were flat but when there is a lift they are even stronger! The nearest point on the French coast is around 110km from here. Dieppe is 125km and Paris 270 km.
ullibg
Beitrag von ullibg » Di 3. Sep 2019, 07:27
I ask you, because some of them are strong like a local station.
MikeF
Beitrag von MikeF » Mi 4. Sep 2019, 12:28
I'll leave the server up for a while. Lots of German stations coming in now. Beaming 80. Try using a narrow bandwidth (~80kHz) and tune slowly up/down the band.
Mike
ullibg
Beitrag von ullibg » Sa 7. Sep 2019, 07:38
Hello Mike, does the peaks above 100Mhz come from a switching power supply?
MikeF
Beitrag von MikeF » Sa 7. Sep 2019, 09:59
Hi Ulli, yes they do. It's a new AIS receiver. I'll be changing the PSU as soon as possible
Mike
MikeF
Beitrag von MikeF » Sa 14. Sep 2019, 08:16
Airspy Discovery is back online now. Lots of very good German and Swiss tropo about. sdr://92.4.75.197:5555
Have fun
Mike
