DX: 14.09.2018 - Tropo (UKW)
atfmdx
Beitrag von atfmdx »
Heute Signale zwischen 150 und 350 Kilometern.
Zum ersten Mal seit 2014 Empfang vom Sender Salzburg/Gaisberg (94,8; 104,6; 243 km, beide 100 kW)
O=5-Empfang mit RDS vom Sender Psunj, Kroatien auf 99,7 MHz. (318 km, 80 kW)
Empfang vom Sender Pecs-Misinatetö, Ungarn auf 103,7 MHz (271 km, 50kW), direkt neben Ortssender 103.8 FM4 Kahlenberg (nur 12km, 100kW)
Empfang aus Budapest/Szechenyi-hegy, Ungarn (94.8, 100.8, 103.3, 107.8; 212 km, 70-90kW)
QTH: Wien, Österreich
Rx: Sony XDR S10 HDiP
QTH: Wien/Vienna, AUT
Rx: Sony XDR S10HDiP, Sangean ATS-909X
FM-DX Logbuch: https://docs.google.com/spreadsheets/d/ ... sp=sharing
MikeF
Re: DX: 14.09.2018 - Tropo (UKW)
Beitrag von MikeF »
Mode Date UTC Frequency ITU Service Location Region Distance (km) Details RDS PI/PS
Tropo 14.09.18 0707 102.00 F Sud Radio Pic du Midi 65 874 YL talks//Web
Tropo 14.09.18 0712 87.90 F France Inter Pic du Midi 65 874 OM talks. Strong. PI logged: F201 PS logged: __INTER_
Tropo 14.09.18 0712 95.70 F France Culture Pic du Midi 65 874 YL talks. Strong PI logged: F202 PS logged: _CULTURE
** denotes new logging (via this propagation mode)
!! denotes YouTube video available at https://www.youtube.com/channel/UCclhK0 ... TuogKGBIgg
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Receivers: Kenwood KT-6050 (80/110 kHz Murata filters) * Sony XDR-F1HD (PC controlled via Seeeduino board & XDR-GTK software v.1.0) * Elad FDM-S2 SDR * Airspy R2 SDR
* Icom R7000 * HS D100 *
Antenna: P.Körner designed 19.4 Yagi (with improved gain & F/B ratio) horizontal at 11m agl / 92m asl ( http://www.ukdx.org.uk/fm/Korner%2019.4 ... 4_yagi.htm ) on a Tennamast 7.6m telescopic / tiltover mast
( http://www.ukdx.org.uk/fm/Tennamast.htm ) * GP cut for ~30MHz * OIRT/STL's 5 ele Yagi * TGN ULNA 3018 Mk.IV Band 2 masthead preamp * CCW Multicoupler feeding all tuners/SDRs
Software: SDR# v1666 * SDR Console v3 * Elad FDM-SW2 v3.019 * RDS Spy v1.02r6 * RDSS v0400 software
Propagation maps produced by FMLIST http://www.fmlist.org/ul_login.php?sprache=en
Propagation Maps and TX sites logged for the Month maps at
http://www.ukdx.org.uk/fm/FMLogs/Prop%2 ... 20Maps.htm
All-time FM log (from 2003) and current month's log at http://www.ukdx.org.uk/fm/FMLogs/FMLogs_index.htm
All-time Meteor Scatter Log map at http://www.ukdx.org.uk/fm/MSMap.htm
North Africa FM Database: http://www.ukdx.org.uk/fm/fm_index.htm
YouTube Channel: https://www.youtube.com/channel/UCclhK0 ... TuogKGBIgg
