Mode Date UTC Frequency ITU Service Location Region Distance (km) Details RDS PI/PS
MS 12.12.15 0017 87.60 ALG Radio Laghouat Aflou 3 1862 YL talks
MS 12.12.15 0116 87.60 TUN RTT Radio Tataouine Zarzis med 2121 Quranic recitation PI logged: 7205 PS logged: TAT?OUI?
MS 12.12.15 0130 87.60 ALG Radio Laghouat Aflou 3 1862 Music
MS 12.12.15 0142 87.60 ALG Chaîne 3 Kef El Akhal 25 1688 OM talks
MS 12.12.15 0157 87.60 ALG Radio Laghouat Aflou 3 1862 Music
MS 12.12.15 0239 87.60 ALG Chaîne 3 Kef El Akhal 25 1688 OM talks
MS 12.12.15 0410 87.60 TUN RTT Radio Tataouine Zarzis med 2121 YL talks PI logged: 7205 PS logged: ????????
MS 12.12.15 0427 87.60 ALG Radio Laghouat Aflou 3 1862 Music//Sat
MS 12.12.15 0503 87.60 ALG Chaîne 3 Kef El Akhal 25 1688 YL talks//Sat
Mike Fallon
Saltdean
East Sussex
UK
N50°48' W0°1'
IO90XT
Kenwood KT-6050 (80/110 kHz Murata filters) * 2 x Kenwood KT-6040s (80/110/150 kHz Murata filters) * Sony ST-SB920 (80/150 kHz Murata filters)
* Sony XDR-F1HD (PC controlled via Seeeduino board & XDR-GTK software v.3.1.7) * Airspy SDR * TGN ULNA 3018 Mk.IV Band 2 preamp
P.Körner designed 19.3 Yagi (horizontal)/K6STI 5 ele vertical yagi on same boom at 11m agl/92m asl ( http://www.ukdx.org.uk/fm/19_3_yagi.htm ) on a Tennamast 7.6m telescopic/tiltover mast
( http://www.ukdx.org.uk/fm/Tennamast.htm ) * CCW Multicoupler feeding the 5 tuners * RDS Spy v1.02r6 software via interface * RDS Spy v1.02r6 software via soundcard * RDSS v0400 software
*RDSDataLogger vBeta14. Some XDR logs generated by StationList
For Low VHF/Band 1 monitoring: Airspy SDR * FunCube Pro+ Dongle * Newsky DVB_T USB RTL2832U/R280T SDR / SDR# Software * Icom R7000 * Icom PCR1000 * Spectrum Lab software * HS D100
* LifeView FlyVideo2000 (SAA1734) TV Card * GP cut for ~30MHz * OIRT/STL's 5 ele Yagi
Propagation Maps and TX sites logged for the Month maps at
http://www.ukdx.org.uk/fm/FMLogs/Prop%2 ... 20Maps.htm
Propagation maps produced by FMLIST http://www.fmlist.org/ul_login.php?sprache=en
All-time FM log (from 2003) and current month's log at http://www.ukdx.org.uk/fm/FMLogs/FMLogs_index.htm
All-time Meteor Scatter Log map at http://www.ukdx.org.uk/fm/MSMap.htm
North Africa FM Database: http://www.ukdx.org.uk/fm/fm_index.htm
YouTube Channel: https://www.youtube.com/channel/UCclhK0 ... TuogKGBIgg
