DX:13.09.2007 TV - Analog
Sorry that I write in english but I just want to share my happinens after 25 years of analog DX.
Diese abend sind einer der besten in viele jahre.
Denk mal an es ist möchlich nach 25 jahren DX immer neue stationen zu bekommen ich denke hier auf Grünten die ich auf UHF nicht gesehen habe nur auf kanal 2
At the moment the local HP tx. 30 km away TV2 - Hove on ch 53 - 600 KW is crushed by NDR 3 which I thougth was extinct in the analog world.Which one is still alive???
5 ARD very poor Inselberg
6 Brocken Guess since stribes are rare on the local Naestved TX DR 1
10 ARD Harz or donnersberg? nearly perfect
21 ZDF Höhbeck nearly perfect
24 ARD Dequede fair B/W
28 ZDF Fair in color (22.35 news) Grünten
33 CZECH 1 Usti N. Labem fair
34 MDR Brocken perfect
35 TVP 2 Poor
39 CZECH 1 Very poor
42 ? CZECH 2 very poor
40 WDR 3 Hochsauerland poor
43 CZECH Liberec poor
44 ARD Sonnenberg weak (Makes me look back of the days of station ID's in the DDR times)
46 BR Grünten poor - First time
49 ZDF Brocken perfect
50 CZECH 2 Usti N. Labem perfect logo up left (It killed TV4 hørby just 100 km away)
53 NDR 3 Perfect but a lot of IF.
Happy DX-ing
Svend
8 km SE of Roskilde - Denmark
2 pc. FUBA XC 391 group C and 9 element band 3 from Triax
35 TVP 2 Poor
Happy DX-ing
Svend
Re: DX:13.09.2007 TV - Analog
Welcome to UKW / TV-DX-Forum, Svend !
Met venlig hilsen (don't know if it is correct),
Matze
Matze
Danke
I dint know that my "old friend" near Hrazen was still alive. Is ARD on channel 10 still alive?
Mathias es ist genant Med Venlig Hilsen
Is it possible to attach pictures?[img]D:\Film\Picture 001.jpg[/img]
Thank you - I'm doing it better next time !Mathias es ist genant Med Venlig Hilsen
Sure ! You can see many examples at the DX: xx.xx.2007 - Sporadic E (TV) - Threads.Is it possible to attach pictures?[img]D:\Film\Picture 001.jpg[/img]
Matze
wow, schon heftig... das Tropo.
You had luck - many of those stations will get off air this year. Harz/Brocken in october, Grünten in November...but will be replaced by DVB-T (digital).
...so if you would have hab a DVB-T-receiver, you might have gotten even more channels.
Very nice logs there, good job!
Danke - es war eine shönen DX abend.
Am nächsten morgen war nur Czech auf kanal 36 mit ein gute pegel.
Ich habe ein Technisat DVB-T aber dvb-t und DX ist nicht wie analog - du weisst was ich meine
Mann muss zu viel signal pegel im gegensatz zum anlog haben und die "tuning knob" ist ein grosses mangel.
"If somebody would build an DVB-T STB with a channel tuning nob - and if it where to scan continously and at the same time read out Signal Quality and any info that it migth decode - That could turn on the fun of DVB-T DX ing"
Svend
Svend
Hi Svend,Danke - es war eine shönen DX abend.
Svend
As far I know you can with every DVBT tuner scan via 'manual scan' per channel and you always see the signal bar. So you can point your antenna for the best signal.
Ruud
DVB-T logbook http://home.wxs.nl/~rabrand/dvbt/dvbtlogboek2006.html
Hi Ruud
Thats rigth but since I use 2 stacked FUBA's then the "window" where DX signals can get the quality meter to move is very small.
I have however tried with an old analog fieldstrength meter which can tell me on which frequency there is weak > 2uV DVB-T signal and then I can move my antenna before I do a scan.
It would be nice if those to actions was tied together.
Svend
Svend
