Sammelthema: Diese Satellitenempfänger können den ARD-Radiotransponder in AAC wiedergeben
Re: Sammelthema: Diese Satellitenempfänger können den ARD-Radiotransponder in AAC wiedergeben
1536kbps bei PCM passt natürlich, 48KHz x 16 Bit x 2 Kanäle. Spannender ist aber wie es vorher aussieht.
Gerne:1536kbps bei PCM passt natürlich, 48KHz x 16 Bit x 2 Kanäle. Spannender ist aber wie es vorher aussieht.
mamba:~>curl http://172.16.0.4/radio/SWR3 -o swr3.mp4
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1028k 0 1028k 0 0 15764 0 --:--:-- 0:01:06 --:--:-- 15750
mamba:~>file swr3.mp4
swr3.mp4: MPEG-4 LOAS
Mein ts2shout schreibt:
[Mon Jul 05 21:26:14.728169 2021] [ts2shout:info] [pid 23774] init_structures(): Subscribing to MPEG-TS PID 0, 17, 18 (CHANNEL_TYPE_PAT, CHANNEL_TYPE_SDT, CHANNEL_TYPE_EIT)
[Mon Jul 05 21:26:14.728213 2021] [ts2shout:info] [pid 23774] ts2shout version v0.93-2-g5d12b5d compiled 04.07.2021 20:02 started
[Mon Jul 05 21:26:14.728218 2021] [ts2shout:info] [pid 23774] MPEG streaming without shoutcast support, audio only in CGI mode with RDS support.
[Mon Jul 05 21:26:14.729429 2021] [ts2shout:info] [pid 23774] fetch_cached_parameters(): found parameters for programme SWR3
[Mon Jul 05 21:26:15.157710 2021] [ts2shout:info] [pid 23774] add_channel(): Subscribing to MPEG-TS PID 530 (Type CHANNEL_TYPE_PMT)
[Mon Jul 05 21:26:15.157745 2021] [ts2shout:info] [pid 23774] extract_pat_payload(): Added 1 possible PMT id(s) with transport_stream_id: 1039.
[Mon Jul 05 21:26:15.438898 2021] [ts2shout:info] [pid 23774] add_payload_from_pmt(): Audio `AAC profile, Level 2'
[Mon Jul 05 21:26:15.438943 2021] [ts2shout:info] [pid 23774] add_payload_from_pmt(): stream language `deu'
[Mon Jul 05 21:26:15.438960 2021] [ts2shout:info] [pid 23774] add_payload_from_pmt(): Found HE-AAC audio stream in PID 531 (service_id 10443)
[Mon Jul 05 21:26:15.438976 2021] [ts2shout:info] [pid 23774] add_channel(): Subscribing to MPEG-TS PID 531 (Type CHANNEL_TYPE_PAYLOAD)
[Mon Jul 05 21:26:15.439228 2021] [ts2shout:info] [pid 23774] Synced to HE-AAC, Guessed Samplerate 48000 Hz, Bitrate 128 kBit/s
[Mon Jul 05 21:26:15.737595 2021] [ts2shout:info] [pid 23774] SDT: Stream is station SWR3 from network ARD SWR.
[Mon Jul 05 21:26:15.838287 2021] [ts2shout:info] [pid 23774] EIT: Current transmission `Probebetrieb bis 20.07.2021'
[Mon Jul 05 21:27:53.558235 2021] [ts2shout:info] [pid 23774] curl_download: Terminated after fetching 6.25 MB and writing 1.49 MB. Exiting.
gucken wir mal bei SWR2
mamba:~>curl http://172.16.0.4/radio/neu_SWR2 -o swr2.mp4
100 888k 0 888k 0 0 31261 0 --:--:-- 0:00:29 --:--:-- 31827
mamba:~>file swr2.mp4
swr2.mp4: MPEG-4 LOAS
[Mon Jul 05 21:28:38.398341 2021] [ts2shout:info] [pid 23799] init_structures(): Subscribing to MPEG-TS PID 0, 17, 18 (CHANNEL_TYPE_PAT, CHANNEL_TYPE_SDT, CHANNEL_TYPE_EIT)
[Mon Jul 05 21:28:38.398450 2021] [ts2shout:info] [pid 23799] ts2shout version v0.93-2-g5d12b5d compiled 04.07.2021 20:02 started
[Mon Jul 05 21:28:38.398467 2021] [ts2shout:info] [pid 23799] MPEG streaming without shoutcast support, audio only in CGI mode with RDS support.
[Mon Jul 05 21:28:38.401767 2021] [ts2shout:info] [pid 23799] fetch_cached_parameters(): found parameters for programme neu_SWR2
[Mon Jul 05 21:28:38.974957 2021] [ts2shout:info] [pid 23799] add_channel(): Subscribing to MPEG-TS PID 520 (Type CHANNEL_TYPE_PMT)
[Mon Jul 05 21:28:38.974993 2021] [ts2shout:info] [pid 23799] extract_pat_payload(): Added 1 possible PMT id(s) with transport_stream_id: 1039.
[Mon Jul 05 21:28:38.975064 2021] [ts2shout:info] [pid 23799] add_payload_from_pmt(): Audio `AAC profile, Level 4'
[Mon Jul 05 21:28:38.975071 2021] [ts2shout:info] [pid 23799] add_payload_from_pmt(): stream language `deu'
[Mon Jul 05 21:28:38.975077 2021] [ts2shout:info] [pid 23799] add_payload_from_pmt(): Found HE-AAC audio stream in PID 521 (service_id 10442)
[Mon Jul 05 21:28:38.975082 2021] [ts2shout:info] [pid 23799] add_channel(): Subscribing to MPEG-TS PID 521 (Type CHANNEL_TYPE_PAYLOAD)
[Mon Jul 05 21:28:38.975141 2021] [ts2shout:info] [pid 23799] Synced to HE-AAC, Guessed Samplerate 48000 Hz, Bitrate 256 kBit/s
[Mon Jul 05 21:28:39.433601 2021] [ts2shout:info] [pid 23799] EIT: Current transmission `Probebetrieb bis 20.07.2021'
[Mon Jul 05 21:28:40.055314 2021] [ts2shout:info] [pid 23799] SDT: Stream is station SWR2 from network ARD SWR.
[Mon Jul 05 21:29:12.893641 2021] [ts2shout:info] [pid 23799] curl_download: Terminated after fetching 2.72 MB and writing 1.03 MB. Exiting.
Hier sind es stolze 256 kBit/s. Ob es konzeptionell überhaupt erlaubt ist, den nackten Audiostrom zu extrahieren, weiß ich nicht, mplayer et.al. spielen die resultierenden Dateien aber ab.
Grüße,
Carsten
Hallo Carsten (und der Rest), das ist ja alles ganz nett, aber bitte das Topic beachten.
Hier im Thread geht es nur um die Empfangsmöglichkeit der Receiver, alles andere, unter anderem auch die technischen Parameter usw., können im KEF Thread gepostet werden.
Danke.
Danke.
Sorry, das hab ich wohl angestoßen
Hier noch kurz meine Beobachtungen.
Receiver: Edision OS mio+ 4K. Ein Linux E2 Receiver.
Signalkette: Edision - HDMI - Marantz SR5010 - Sennheiser HD660.
Die folgenden Programme gehen nur mit Aussetzern:
- SWR2
- hr3 (tlw. bis zu 1s weg)
- YOU FM (tlw. bis zu 1s weg)
- SWR4 RP
- WDR3
- WDR4
- Die Maus
Die Programme werden mit Klarnamen im Display angezeigt, das altgewohnte durchscrollen des "Radiotextes" von oben nach unten ist natürlich nicht vorhanden. Größere akustische Grausamkeiten konnte ich keine feststellen, nur bei Jump und Sputnik ist definitiv Luft nach oben. Das Geschmirgel ist grenzwertig und DAB-like. Ausgerechnet die MDR-Programme laufen mit dem Edision aber ohne Aussetzer.
Richtig knackig wurde es bei NDR Kultur. Da fegte plötzlich ein Wahnsinns-Sound durch die Gehörgänge, in einer Lautstärke bei der ich fast den Kopfhörer weggeschmissen hätte. Ich musste den Marantz von -18dB auf -40dB runterdrehen, um dieselbe Lautstärke wie bei den anderen Programmen zu haben. Kurz auf die Infotaste gedrückt, aha, NDR Kultur liest der Marantz in Dolby Digital ein. Alle anderen Programme (auch die Kulturprogramme) wurden nur in PCM Stereo zum Marantz geliefert. Kurz den Kopfhörer abgestöpselt, Jawoll, das Klavierkonzert machte akustisch richtig Spaß. Das Teufel Theater 500 System hat kurz den Staub von den Regalen gepustet. Die S-Laute sind bei Wortbeiträgen leicht verzischelt, ansonsten ist das was der NDR da veranstaltet, schon ziemlich genau das was ich mir vorstelle.
Ich muss mir das Ganze nochmal mit einem 2-Kanal-Verstärker geben.
EDIT:
Die Aussetzer bei o.g. Programmen waren nicht wegzubekommen, auch nicht durch Ein/Aus oder hin- und herschalten. Der Receiver will die Programme einfach nicht.
- SWR2
- SWR4 RP
- WDR3
- WDR4
- Die Maus
EDIT:
hoi,
Vantage HD 8000S von baujahr 2010:
Alle Programme laufen ohne Probleme.
Heute Abend getestet:
Mein Fernseher Samsung LE32C678 von 2010 gibt alle Radioprogramme fehlerfrei wieder.
Der Technisat Digicorder HD S3 (ca. 2011) liest sie zwar ein, kann sie aber mangels AAC-Codec nicht wiedergeben. Nur das eine Kulturprogramm, das AC3 verwendet, läuft.
Der auch nicht... das kann doch nicht wahr sein. Was für eine Endgeräteentwertung! Bitte melde das Gerät unter zuschauer@ard-digital.de . Premium-HDTV-Gerät mit Programmnamenanzeige, sicher auch mit RDS-Anzeige auf dem Hörfunktransponder, mit Festplatte, selbstverständlich HDTV-tauglich, sogar nen CI+ hat er (und nicht mehr nur einen CI) - und Radio soll er nicht mehr können. Grandios.
Erledigt! Freilich erwarte ich nicht mehr als die Formantwort, die mir auch von meiner Landesanstalt bereits vorliegt. Sinngemäß: Ich soll neu kaufen, mein Gerät wäre veraltet und kann deshalb den neuen Standard nicht wiedergeben. Verbunden mit dem unvermeidlichen Hinweis auf die Webstreams und DAB+. Klanglich sind das Welten zu den MP2-Streams!Chris_BLN hat geschrieben: ↑Di 6. Jul 2021, 23:34 [...] Was für eine Endgeräteentwertung! Bitte melde das Gerät unter zuschauer@ard-digital.de . Premium-HDTV-Gerät mit Programmnamenanzeige, sicher auch mit RDS-Anzeige auf dem Hörfunktransponder, mit Festplatte, selbstverständlich HDTV-tauglich, sogar nen CI+ hat er (und nicht mehr nur einen CI) - und Radio soll er nicht mehr können. Grandios.
Mit dieser dreisten Masche, HDTV-Geräte auszuschalten, dürfen sie nicht durchkommen. Noch ist nicht Mitte Dezember...
Zuletzt geändert von Chris_BLN am Mi 7. Jul 2021, 08:50, insgesamt 1-mal geändert.
Erledigt war die Mail... Passieren kann noch viel. Allein der Glaube daran fehlt mir.
Zuletzt geändert von PAM am Mi 7. Jul 2021, 08:51, insgesamt 1-mal geändert.
Im aktuellen Testbetrieb nach dem Neueinlesen der ARD-Radioprogramme funktioniert (noch) nicht:
- Hersteller: Schwaiger
- Typ: DSR596HDCI
- Beistellgerät/Set-Top-Box
- Gebrauchtkauf < 50 EUR
Getestet am 06.07. mit rbb Info, rbb radio eins, WDR Die Maus, Bayern 2 (alle negativ).
Vorschau ("i"-Taste) liefert "Testbetrieb bis 20.07."
- Typ: DSR596HDCI
TV: DENVER 506 (inaktiv)
...würde doch eher in das Thema gehören, welche Geräte es nicht können.
LWie hat geschrieben: ↑Mi 7. Jul 2021, 18:10 Im aktuellen Testbetrieb nach dem Neueinlesen der ARD-Radioprogramme funktioniert (noch) nicht:
- Typ: DSR596HDCI
Hersteller: Vu+ Zero (OHNE 4K)
Image: VTi 15.0.00
Gestern 6.7.21 noch mit Aaussetzer, seit heute 7.7.21 einwandfreie Wiedergabe aller ARD-AAC Radioprogramme.
Image: VTi 15.0.00
