Seite 58 von 111
Re: NXP TEF6686 auf Arduino
Verfasst: Fr 3. Mär 2023, 11:17
von ArthurSRB
andimik hat geschrieben: ↑Fr 3. Mär 2023, 08:51
Eine Favoritenliste ist doch kein Quantensprung, dass 8 Versionsnummern übersprungen wird
Google doesn't translate German well for me, the memory mode is 2×32 positions with a number of additional combinations, a unique solution for DX!
Verfasst: Fr 3. Mär 2023, 12:31
von andimik
Understood of course, but I wonder why the Japanese have skipped 8 version numbers...
Hope you all work together and provide a UNIQUE version and not different branches with different features.
Verfasst: Fr 3. Mär 2023, 12:45
von ArthurSRB
You didn't understand anything, it's not the Japanese, but the Serbs, but since the engineer is on vacation in Japan, there is also a recording of their radio stations.
Verfasst: Fr 3. Mär 2023, 13:05
von andimik
You wrote, the software is made in Japan.
Verfasst: Fr 3. Mär 2023, 13:15
von ArthurSRB
Well, yes, while he was there for a few days on vacation, he started the development, now he is here and continues it.
Verfasst: Fr 3. Mär 2023, 17:07
von dtd
ArthurSRB hat geschrieben: ↑Di 28. Feb 2023, 17:15
dtd hat geschrieben: ↑Di 28. Feb 2023, 17:01
Hello! Can you try to put the battery indicator on the Home Screen if possible?
Just a question considering AF: is it a full working AF like does it switch the frequency automatically like the car radios?
It has been implemented.
We have some other plans with AF, but whatever you think should be,we will consider whether it is possible to implement.
Sounds nice! Thanks for your reply!
Verfasst: Sa 4. Mär 2023, 07:48
von yo2ldk
ArthurSRB hat geschrieben: ↑Fr 3. Mär 2023, 07:45
this project will be shared as ino file or bin?
I ask because I made an DIY tuner with 4" ILI9488, and your firmware look to be very promising,
on 4 inch is a lot space for info..
Verfasst: Sa 4. Mär 2023, 11:30
von ArthurSRB
I would like to mention once again that a top expert and professional works as a firmer and that the basic version will undergo certain changes with a lot of new functions.
That's why it takes a lot of effort and time.
If the Chinese would mass-produce a device with screen dimensions like yours, then it would be a priority.
For now, the development is going in this direction, if possible, we will respect your wishes.
Since the S-meter does not accurately display the field strength on the FM band, we try to bring the whole concept closer to a professional level.
What do you think would be better dBf or dBm for the new meter ?
Verfasst: So 5. Mär 2023, 19:19
von Gelo96.5
Guten Abend.
Ich wollte mal fragen, welche Antenne man als Ersatz für die mitgelieferte Teleskopantenne kaufen sollte.
Weil wenn mir die normale unterwegs beim scannen kaputt geht, dann hab ich nichts davon.
Grüße
Verfasst: So 5. Mär 2023, 19:23
von NoobishSVK
ArthurSRB hat geschrieben: ↑Sa 4. Mär 2023, 11:30
Hello, since you mentioned multiple times that you have a top expert programmer, first of all, I'd expect the software to be written from scratch.
Instead I see that you are using my fork of software, which is open-source, however it's licensed under the GNU-GPL v3.0 license - I am sure you have read the license terms and conditions and will publish the source code of your firmware as well. If not, you will be violating the license conditions. I wish the best in making your fork of the software and I'm excited to see the project's source code!
Verfasst: So 5. Mär 2023, 20:39
von Vonderalb
Gelo96.5 hat geschrieben: ↑So 5. Mär 2023, 19:19
Guten Abend.
Grüße
Ich habe mir die beiden Antennen von Seite 55 gekauft und bin zufrieden. Hier ist der Original Thread:
Beitrag Mi 22. Feb 2023, 15:24
Harald Z hat geschrieben: ↑...Die mitgelieferten achtgliedrigen Teleskopantenennen sind beim Siberfarbenen 16,4/74 cm und beim Blauen 20,5/103 cm. ..
Für beide gilt: Der UKW Empfang verbessert sich etwas, wenn die Antenne 92…95 cm hat. Mehr als 95 cm bringt keine weitere Verbesserung...
Aber beim Blauen wird meist die leicht zerbrechliche Variante der Stabantenne mit der Sechskant Überwurfmutter geliefert.
Ich habe mir
https://www.dx-wire.de/antennen/telesko ... anner.html zugelegt -96 cm mit Adapter-.
Hat aber auch Nachteile: Mindestbestellung 20,-- also 2 Stück bestellen (zweites Exemplar von mir ist leider schon vergeben).
Das ein (vergülteter) notweniger Adapter dabei ist, gefällt auch nicht jeden.
BNC ist ein Bajonettverschluss. Da muss man beim an- und abstecken nicht so viel Drehen (wenn man den Adapter immer am Gerät lässt
Verfasst: So 5. Mär 2023, 21:48
von _Yoshi_
Der Grund, warum die vielfach abbricht ist, dass die kein Drehgelenk hat.
Das ist auch einer der Gründe, dass ich die gleich bei Seite gelegt habe und stattdessen einen Teleskopdipol verwende.
Verfasst: So 5. Mär 2023, 21:56
von DXHR
_Yoshi_ hat geschrieben: ↑So 5. Mär 2023, 21:48
Gibt es irgendwo gute Teleskopdipole zu kaufen?
Verfasst: So 5. Mär 2023, 22:06
von _Yoshi_
Da muss man mal bei Ebay schauen, hin und wieder werden die da angeboten.
Diese waren früher immer bei den kleineren Koffer Röhrenfernseher dabei.
Wie z.b. Sowas
https://www.ebay.de/itm/266151540078?ha ... SwBG9jVTn2
Mit so einer Antenne kann ich Nachbarkanalstörer gezielt ausblenden und der TEF regelt dann die Filterbreite auf so das RDS Ausgelesen werden kann.
Ich kann hier sehr oft ffh auf der 105,1MHz Empfangen mit RDS.
Auch 1LIVE 105,5 oder 107,9 geht damit oft mit RDS.
Verfasst: So 5. Mär 2023, 22:18
von DXHR
_Yoshi_ hat geschrieben: ↑So 5. Mär 2023, 22:06
Wie z.b. Sowas
Ah, so eine hab ich tatsächlich rumliegen hier aber der Empfang ist bedeutend schlechter als mit meiner selbstgebauten Dipolantenne.
