Google doesn't translate German well for me, the memory mode is 2×32 positions with a number of additional combinations, a unique solution for DX!andimik hat geschrieben: ↑Fr 3. Mär 2023, 08:51Eine Favoritenliste ist doch kein Quantensprung, dass 8 Versionsnummern übersprungen wirdArthurSRB hat geschrieben: ↑Do 2. Mär 2023, 20:17 Software 1.30 (Made in Japan)
https://streamable.com/wv0m06
NXP TEF6686 auf Arduino
Re: NXP TEF6686 auf Arduino
Understood of course, but I wonder why the Japanese have skipped 8 version numbers...
Hope you all work together and provide a UNIQUE version and not different branches with different features.
You didn't understand anything, it's not the Japanese, but the Serbs, but since the engineer is on vacation in Japan, there is also a recording of their radio stations.
You wrote, the software is made in Japan.
Well, yes, while he was there for a few days on vacation, he started the development, now he is here and continues it.
I would like to mention once again that a top expert and professional works as a firmer and that the basic version will undergo certain changes with a lot of new functions.
That's why it takes a lot of effort and time.
If the Chinese would mass-produce a device with screen dimensions like yours, then it would be a priority.
For now, the development is going in this direction, if possible, we will respect your wishes.
Since the S-meter does not accurately display the field strength on the FM band, we try to bring the whole concept closer to a professional level.
What do you think would be better dBf or dBm for the new meter ?
Guten Abend.
Ich wollte mal fragen, welche Antenne man als Ersatz für die mitgelieferte Teleskopantenne kaufen sollte.
Weil wenn mir die normale unterwegs beim scannen kaputt geht, dann hab ich nichts davon.
Grüße
Grüße
HN
Lieblingssender: SWR1 BW, SWR3 am liebsten via UKW
Lieblingssendung: SWR1 Stadion, SWR1 Arbeitsplatz, SWR1 BW Bloß kein Stress, SWR3 Playlist, SWR3 Move mit Wirby und Zeus
TEF6686
TEF6686
Hello, since you mentioned multiple times that you have a top expert programmer, first of all, I'd expect the software to be written from scratch.ArthurSRB hat geschrieben: ↑Sa 4. Mär 2023, 11:30 I would like to mention once again that a top expert and professional works as a firmer and that the basic version will undergo certain changes with a lot of new functions.
Instead I see that you are using my fork of software, which is open-source, however it's licensed under the GNU-GPL v3.0 license - I am sure you have read the license terms and conditions and will publish the source code of your firmware as well. If not, you will be violating the license conditions. I wish the best in making your fork of the software and I'm excited to see the project's source code!
Ich habe mir die beiden Antennen von Seite 55 gekauft und bin zufrieden. Hier ist der Original Thread:
Beitrag Mi 22. Feb 2023, 15:24
Harald Z hat geschrieben: ↑...Die mitgelieferten achtgliedrigen Teleskopantenennen sind beim Siberfarbenen 16,4/74 cm und beim Blauen 20,5/103 cm. ..
Für beide gilt: Der UKW Empfang verbessert sich etwas, wenn die Antenne 92…95 cm hat. Mehr als 95 cm bringt keine weitere Verbesserung...
Aber beim Blauen wird meist die leicht zerbrechliche Variante der Stabantenne mit der Sechskant Überwurfmutter geliefert.
Ich habe mir https://www.dx-wire.de/antennen/telesko ... anner.html zugelegt -96 cm mit Adapter-.
Hat aber auch Nachteile: Mindestbestellung 20,-- also 2 Stück bestellen (zweites Exemplar von mir ist leider schon vergeben).
Das ein (vergülteter) notweniger Adapter dabei ist, gefällt auch nicht jeden.
BNC ist ein Bajonettverschluss. Da muss man beim an- und abstecken nicht so viel Drehen (wenn man den Adapter immer am Gerät lässt
Der Grund, warum die vielfach abbricht ist, dass die kein Drehgelenk hat.
Das ist auch einer der Gründe, dass ich die gleich bei Seite gelegt habe und stattdessen einen Teleskopdipol verwende.
SDR AirSpy One mit SDR#
TEF6686 Radio
My Snip †01.09.2018 11.21Uhr
TEF6686 Radio
Gibt es irgendwo gute Teleskopdipole zu kaufen?
Standort: Wien, Österreich
Da muss man mal bei Ebay schauen, hin und wieder werden die da angeboten.
Diese waren früher immer bei den kleineren Koffer Röhrenfernseher dabei.
Wie z.b. Sowas https://www.ebay.de/itm/266151540078?ha ... SwBG9jVTn2
Mit so einer Antenne kann ich Nachbarkanalstörer gezielt ausblenden und der TEF regelt dann die Filterbreite auf so das RDS Ausgelesen werden kann.
Ich kann hier sehr oft ffh auf der 105,1MHz Empfangen mit RDS.
Auch 1LIVE 105,5 oder 107,9 geht damit oft mit RDS.
TEF6686 Radio
TEF6686 Radio
Ah, so eine hab ich tatsächlich rumliegen hier aber der Empfang ist bedeutend schlechter als mit meiner selbstgebauten Dipolantenne._Yoshi_ hat geschrieben: ↑So 5. Mär 2023, 22:06 Da muss man mal bei Ebay schauen, hin und wieder werden die da angeboten.
