AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Re: AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
I make some tests...
Are you really using the app like this? I have to do something with that, it looks so bad
Normaly I don´t use fullscreen.
Much better, thank you
Version 1.99.2 source code is available - binary builds will be released tomorrow
Changes:
- DABSDR 2.0.0 (Windows DLL will be release tomorrow)
- new handling of some service features (announcement support, user applications, programme type)
- RAW file device is temporary removing service list, it is restored when switching back to physical device
WARNING: Windows compilation is not working due to missing DABSDR library DLL. It should be fixed tomorrow.
Changes:
Version 1.99.2 binaries are available for download here https://github.com/KejPi/AbracaDABra/re ... ag/v1.99.2
It is still testing version but reasonably stable, please test and report problems.
Bei mir unter Windows 11 läuft die Andy Software ohne Propleme ,bei der Abracadabra Software kein Empfang
Nutzt du rtl_tcp oder die Hardware - Treiber für den DAB Player?
If you use HW directly, you need different drivers for AbracaDABra and for DAB Player. AbracaDABra (and other RTL_SDR based applications) need Zadig drivers for Windows while DAB Player uses Realtek drivers available on its download page.
Short instructions how to install RTL_SDR drivers for Windows are for example here: https://www.rtl-sdr.com/getting-the-rtl ... indows-10/
danke jetzt gehts
Jetzt gehts nach den Treiber Update aber jetzt geht der andy Player nicht mehr
Doch, du musst nur den Player mit dem Parameter rtltcp starten. Such einfach nach diesem Wort.
Leider ist das im Player offenbar noch immer undokumentiert, weil nur die anfangs enthaltenen Parameter genannt werden.
As I wrote - DAB Player and AbracaDABra need different drivers - it means only one can work with the drivers installed.
The best workaround is probably to run DAB player via rtl_tcp as proposed by andimik.
1) Install Zadig drivers => AbracaDABra should work with them
2) If you want to run DAB playe, start rtl_tcp. You can get probably the best performing version here: https://github.com/old-dab/rtlsdr/releases
3) Start DAB Player with RTLTCP option: DAB_Player.exe -RTLTCP
Explanation: all RTL_SDR based SW needs Zadig driver under Win, the only exception as far as I know is DAB player that uses Realtek drivers. With Zadig driver you can also run QIRX, welle.io or Qt-DAB. Fortunately, DAB Player can work with RTL_TCP that is compatible with Zadig driver.
The other option would be to reinstall drivers each time you want to switch from DAB Player to AbracaDABra or vice versa.
PS: AbracaDABra can also run with RTL_TCP server but direct usage of the driver is IMO better.
Zadig is not a driver, it is a tool to deinstall the default windows driver for the USB device.
Yes, you are right. I will also probably include it in the next release of Windows binary.
