AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Re: AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
If I click on the installed program file with open option it gives up wthout any response just one time short moving of the icon
For debuggig in finder I started abracaDABra not with open option but show content of package in german "Paketinhalt anzeigen"
I then navigated to /Contents/MacOS then right click on the shell script of AbraCaDABra selecting open.
This opens the shell window and shows shows the error I posted in my last message.
For testing I did the same on version 2.2.4 and it displayed reading the config and started abracaDABra as normal,
We can now change to PM. I will try to help to solve the problem.
Right click means ctrl click
greetings Sven
greetings Sven
Thank You for the fix on fading signals.
I have tested MDR Sachsen and Citymux Wien...
All is working correct.
FYI: It seems that RadioDNS service provided by RadioPlayer will no longer work: https://support.radioplayer.co.uk/suppo ... ns-service
FEC stands for Forward Error Correction that is Reed Solomon in case of DAB. It shall be used for packet data services although there might be still some transmissions without it. It is signalled in FIG 0/14. As there might be cases without it, it is explicitly mentioned in ensemble description.
But I don't understand why the text doesn't appear each time I switch to the ensemble.
It could be because the information was not yet received at the time the application is creating the description. It should not happen because FIG0/14 shall be signalled each 96ms but if you can reproduce this behaviour on particular ensemble I would like to analyze this case.
AbracaDABra 2.3.5 has been released
Changes:
Arch Linux users can install AbracaDABra from AUR
If you have any problem please report here or enter new issue on GitHub
Thanks to everyone who reported problems and shared recordings!
Changes:
- small bug fixes
This is preview of new feature I am working on now. Do you like it?
Cool!
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Wittenberg WB345
VU+ Solo²
Multytenne
Will you integrate a timer?
If yes: And for services without SPI EPG a manual timer
What kind of timer do you mean?
Currently I am using a hack (your debug parameter) to start the tool delayed and automatically record the service and shutdown then.
Because I regularly record a weekly radio show for around 25 years now just digitally.
Oh, that is an interesting feature. Actually I dod not plan tom implement it but I will add it to my to do list.
Cheap USB sticks have inaccurate crystals. My worst stick has a 50 ppm deviation! I therefore miss a setting option for ppm in "RTL SDR" and "RTL TCP" in Abracadabra. The first picture shows the stick without correction. In the second picture I corrected the quartz in the command line of rtl_tcp.exe. The difference of SNR is huge.
- Dateianhänge
- 50ppm.png (4.4 KiB) 1876 mal betrachtet
- 0ppm.png (4.32 KiB) 1876 mal betrachtet
