AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Re: AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
That should be easy to add. I will do it in next version.
BTW
Don't forget to hide the new menu item when there is no EPG (use Grey font color).
Same for the last checkbox regarding SPI, when the Internet checkbox is not active.
It is problem on Linux, I cannot do anything with that, the contol is inactive but on Linux the font does not chnage for some reason. It works as expected on both MacOS and Windows.
Oh, interesting.
Yes, the interesting point is that it was working with the same version of Ubuntu and Qt in past. Maybe there was some LTS update that broke something but it can be also reproduced using example project coming with Qt. I thought is was problem with my Ubuntu setup but obvously not because you have noticed it too.
EDIT: Do you compile tha app with default Qt version (6.2.x) or do you use newer version?
Try now, please!
Is it possible to make the slideshow "apng" compatible?
/// www.DABmonitor.COM ///
Privat Kfz - Škoda Columbus
Well, I did already some investigation on that point some time ago. The problem is that Qt6 does not support APNG, thus the implementation would be tricky and it would create problems for users who build the app by themselves because it would essentially require to use patched version in image plugins. I have tried that to verify that it would be possible (yes, it would) but at that time the conclusion was not to implement it in upstream unless there will be a real use case - as far as I know there is only some experimental broadcasting with APNG slides. I should have a recording. Do you have regular ensemble that broacasts APNG?
That's what I thought, that it is difficult to implement.
Radio UNiCC from Chemnitz uses (as the only one in Germany) apng graphics. I would be happy to provide you with a recording.
Via a separate mux (opendab-tools) with apng it could only be detected in audio DAB radio, as this is supported. Also in the web browser via the PAD from DABmonitor (DR Box).
Thanks, actually I think the recording I have is that ensemble. And it is the only one I know that broadcasts APNG. I will put this feature in my TODO list but with very low priority, I have already many TODO items and not enough time to work on them.
I was wondering whether it could be implemented "just like that".
Thank you!
Thank you!
Confirmed, now it works.
- Dateianhänge
- Bildschirmfoto vom 2024-01-31 17-40-51.png (14.81 KiB) 647 mal betrachtet
thanks for your support, now I have data from today started Slovene EPG
What does the
mean? All other pngs do NOT have this suffix.
There is one service, where the SPI logo is wrong. So I guess this might be an internal app mismatch
[complete]
18:31:44.862 [D] SPIApp: 0: Object 46693 -> TRIGLAV_32_32.png [complete]
18:31:44.862 [D] default: Processing object: "TRIGLAV_32_32.png"
18:31:44.862 [D] SPIApp: 0: Object 37472 -> TRIGLAV_320_240.png [complete]
18:31:44.862 [D] default: Processing object: "TRIGLAV_320_240.png"
18:31:44.863 [D] SPIApp: 0: Object 31489 -> si.xml [complete]
