AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Re: AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Frage des Treibers.
Ich stehe vor dem umgekehrten Problem.
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Wittenberg WB345
VU+ Solo²
Multytenne
Für die Software wird kein separater Treiber benötigt.
Noxon DAB Stick ( Rev. 2 ) funktioniert einwandfrei damit, musste allerdings die Zadig Treiber installieren.
Realtek drivers that DAB Player needs are NOT compatible with AbracaDABra. You need to install Zadig to make stick working with AbracaDABra and any other application except DAB Player. Short instructions are here: https://github.com/KejPi/AbracaDABra#windows
BTW Für Linux auch.
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Wittenberg WB345
VU+ Solo²
Multytenne
What do you think, could your (excellent) library replace the one from Jan? Of course Jan's tools are excellent too, but not so sensitive in my opinion.
I have lots of muxes where I have no single dropout with AbracaDABra, but Jan's tools (eti-cmdline, Qt-DAB) have severe problems or cannot even lock in one case.
It is freely available so anyone can use it as he want. Nevertheless I do not see realistic to replace demodulation library I other tool by my DABSDR. Why would you do it? You can use it i AbracaDABra, it there any particular feature you are missing?
Yes, for ETI-NI generation I am using eti-cmdline, so I can use dablin_gtk or record it to an eti file (which is much smaller than xml/raw files).
For single service recording, I uncomment the debug mode
$ git diff
diff --git a/gui/audiodecoder.h b/gui/audiodecoder.h
index cf7928c..8356854 100644
--- a/gui/audiodecoder.h
+++ b/gui/audiodecoder.h
@@ -56,7 +56,7 @@
// debug switches
//#define AUDIO_DECODER_RAW_OUT
-//#define AUDIO_DECODER_AAC_OUT
+#define AUDIO_DECODER_AAC_OUT
//#define AUDIO_DECODER_MP2_OUT
enum class AudioCoding
ETI decoding is not supported by library, so it would not be solution for you. Audio recording might be added if I find a way to integrate it with existing UI.
Ah, then I can forget my idea ... Thanks for the info anyway!
Ich habe ein MacBook mit M2 Chip und bekomme meinen Noxon Stick nicht zum laufen mit dieser Software.
Kann u.a. natürlich auch an meinem schlechten englisch liegen
I do not have M2 version, I only have M1 and it works fine.
You can switch language in Settings, but the application should start automatically in system language if it is supported.
Please share the application log (Menu -> Application log) so that I can figure out what is going on.
