Hilfe! - Noxon DAB+ Stick unter Linux
KejPi
Re: Hilfe! - Noxon DAB+ Stick unter Linux
Beitrag von KejPi »
You need librtlsdr that is the library used by all the tools, it will be installed automatically when you do
sudo apt install rtl-sdr
librtlsdr-dev will be needed in case you want to compile some of the apps.
He wrote he already installed it.
the jazzman
Beitrag von the jazzman »
KejPi hat geschrieben: Mi 27. Jul 2022, 13:57
the jazzman hat geschrieben: Mi 27. Jul 2022, 13:46 rtlsdr ist installiert, mittels WINE/PlayOnLinux Treiber1.zip.
This is not the way how to make it running under Linux. You do not need Wine or any kind of emulation to run Linux versions of Qt-DAB, Welle-io or AbracaDABra. You might need it for DAB Player.
To install rtl-sdr, just follow Ubuntu related instructions, for example here: https://installati.one/ubuntu/20.04/rtl-sdr/
And do not run Wine while trying with Linux tools, it rtl_test works then the other tools should work too.
AbracaDABra AppImage shoud contain all necessary libs, but of course HW must be functional on system level.
I followed the instructions given viewtopic.php?p=1667698#p1667698
rtl_test -t
Found 1 device(s):
  0:  Realtek, RTL2832U, SN: 00000001
Using device 0: Terratec NOXON DAB/DAB+ USB dongle (rev 2)
Detached kernel driver
Found Elonics E4000 tuner
Supported gain values (14): -1.0 1.5 4.0 6.5 9.0 11.5 14.0 16.5 19.0 21.5 24.0 29.0 34.0 42.0
Sampling at 2048000 S/s.
Benchmarking E4000 PLL...
[E4K] PLL not locked for 51000000 Hz!
[E4K] PLL not locked for 2199000000 Hz!
[E4K] PLL not locked for 1100000000 Hz!
[E4K] PLL not locked for 1267000000 Hz!
E4K range: 52 to 2198 MHz
E4K L-band gap: 1100 to 1267 MHz
Reattached kernel driver
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Starte mal das Qt-DAB appImage von der Konsole mit der Syntax "./Pfad/Qt-dab-datei-wie-auch-immer-die-heißt" und kopiere das Ergebnis und füge es als Text hier ein.
Ich kann mir nicht vorstellen, dass es nicht funktionieren sollte.
the jazzman
AbracaDABra AppImage does not run.
Addendum: glibc on Mint 20.3 is still version 2.31
Zuletzt geändert von the jazzman am Mi 27. Jul 2022, 16:06, insgesamt 1-mal geändert.
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
the jazzman
andimik hat geschrieben: Mi 27. Jul 2022, 15:08 Starte mal das Qt-DAB appImage von der Konsole mit der Syntax "./Pfad/Qt-dab-datei-wie-auch-immer-die-heißt" und kopiere das Ergebnis und füge es als Text hier ein.
./Qt_DAB-x86_64-4.4.AppImage
main: Detected system language "de_DE"
main: Set language "de_DE"
ALSA lib pcm_dsnoop.c:641:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:869:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = Datei oder Verzeichnis nicht gefunden
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Hostapis: 2
Api 0 is ALSA
Api 1 is OSS
Investigating Device 0
 (output):item 1 wordt stream 0 (HDA Intel PCH: ALC255 Analog (hw:0,0))
Investigating Device 1
 (output):item 2 wordt stream 1 (HDA Intel PCH: HDMI 0 (hw:0,3))
Investigating Device 2
 (output):item 3 wordt stream 2 (HDA Intel PCH: HDMI 1 (hw:0,7))
Investigating Device 3
 (output):item 4 wordt stream 3 (HDA Intel PCH: HDMI 2 (hw:0,8))
Investigating Device 4
 (output):item 5 wordt stream 4 (HDA Intel PCH: HDMI 3 (hw:0,9))
Investigating Device 5
 (output):item 6 wordt stream 5 (HDA Intel PCH: HDMI 4 (hw:0,10))
Investigating Device 6
 (output):item 7 wordt stream 6 (sysdefault)
Investigating Device 7
 (output):item 8 wordt stream 7 (front)
Investigating Device 8
 (output):item 9 wordt stream 8 (surround40)
Investigating Device 9
 (output):item 10 wordt stream 9 (surround51)
Investigating Device 10
 (output):item 11 wordt stream 10 (surround71)
Investigating Device 11
 (output):item 12 wordt stream 11 (hdmi)
Investigating Device 12
 (output):item 13 wordt stream 12 (samplerate)
Investigating Device 13
 (output):item 14 wordt stream 13 (speexrate)
Investigating Device 14
 (output):item 15 wordt stream 14 (pulse)
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1736
Expression 'AlsaOpen( hostApi, parameters, streamDir, &pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1768
Investigating Device 15
Investigating Device 16
ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
Investigating Device 17
Investigating Device 18
 (output):item 16 wordt stream 18 (default)
added items to combobox
Suggested size for outputbuffer = 0
stream opened
stream started
channel reset: all services will be stopped
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Komisch.
Ich sehe keine Zeile über den Stick (da müßte der E4000 mit den verschiedenen Gain Einstellungen zu sehen sein).
Hast du dabstick ausgewählt?
the jazzman
Nein, denn dann erhalte ich die Fehlermeldung. DAB-Stick nicht gefunden! Bitte einen mit RTL2832U oder ähnlichem Chipsatz verwenden!
Deswegen rtl_tcp.
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Das ist schon klar. :D Der Text für die Fehlermeldung stammt ja von mir (= ich hab die deutsche Übersetzung gemacht für Qt-DAB).
Aber ich möchte ja wissen, WARUM diese Meldung kommt. Der Output der Konsole würde etwas Licht bringen.
So ganz hab ich jetzt nicht verstanden, ob damit das Problem gelöst wurde oder nicht. Das heißt, bei dir geht Qt-DAB über rtl_tcp und du hast jetzt Empfang?
the jazzman
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Mit dieser spärlichen Antwort kann ich dir leider nicht mehr weiterhelfen und tippe auf einen Anwenderfehler. Der Logik nach muss es funktionieren, denn rtl_test funktioniert ja und welle.io auch.
Dann nutze halt rtl_tcp.
the jazzman
Wie gesagt, bei dabstick kommt die genannte Fehlermeldung. Die anderen Optionen erzeugen auch (natürlich andere) Fehlermeldungen.
Nur bei rtl_tcp kommt erst einmal keine Fehlermeldung.
Ich starte Qt-DAB und empfange nicht einmal die Sender, die in der Stadt stehen (2 unterschiedliche Standorte).
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Geh bitte alle meine Fragen durch.
Nimm bitte rtl_tcp. Du hast ja schon geschrieben, dass es mit rtl_test funktioniert.
the jazzman
Ja, und ein Suchlauf (scan) findet aber dann leider nichts.
Sprich: nur rtl_tcp erzeugt keine Fehlermeldung, der Suchlauf findet leider nirgendwo ein Signal.
RTL-SDR Blog V.3
Wittenberg WB345
VU+ Solo²
Multytenne
Ich habe eine Vermutung. Vielleicht hat dein Stick zwei (2) Interfaces?
Starte mal rtl_tcp mit dem Parameter -d 1 und teste es noch einmal.
Bitte kopiere alles rein, was dir die Konsole sagt. Nur zu sagen, es geht nicht, ist leider überhaupt nicht hilfreich.
Ich nimm an, du wohnst in Deutschland, wo auch der 5C gehen sollte. Wie sieht das Spektrum aus? Du hast nicht geschrieben, WARUM du nichts empfängst. Liegt es am Empfang oder hast du die Einstellungen falsch verwendet (Evtl. die falsche IP??)? Nimm bitte 127.0.0.1 für die IP-Adresse.
Screenshots deines Bildschirms kannst du hier auch anhängen.
Ich hab nun auch das aktuelle AppImage runtergeladen und mit rtl_tcp getestet. Funktioniert mit meinem E4000 genauso wie es sein sollte. Du hast den gleichen Stick und das gleiche Betriebssystem basierend auf Ubuntu.
Ganz wichtig ist die Zeile
set freq 215072000
für 5C natürlich 178,352 MHz
Nur dann ist rtl_tcp richtig verbunden. Im Fenster muss auch connected stehen und nicht disconnected.
Und schreib bitte alle Schritte auf, die du machst. Ich fürchte, du überspringst nämlich einen wesentlichen ...
