Sorry, I don't know....
What about EuroDAB 12A (in Milan 12D) and DAB Italia 12C? Do they play? Or is it a RAI-only problem?
Have you tried to delete the station list ("Stazioni memorizzate")?
Hi,
Exactly the same. They are found but not played.
Thanks
Mario
Thanks
Mario
These are the DAB infos:
RTKDAB.dll: 1.1.1027.2010 (C:\Windows\SysWOW64\RTKDAB.dll)
RTKDABSOURCE.dll: 1.7.1027.0 (C:\Windows\SysWOW64\RTKDABSOURCE.dll)
Rtl283xAccessWrap.dll: 1.0.0.3 (D:\users\mario.public\Archivio\files-installazione\trekstor-dvb-dab-stick\DAB_Player_1-0-2-159_de-en-fr-it-nl-no-pl\Rtl283xAccessWrap.dll)
RTL283XACCESS.dll: 1.1.612.2009 (C:\Windows\SysWOW64\RTL283XACCESS.dll)
ffdshow.ax: 1.3.0.0 (D:\users\mario.public\Archivio\files-installazione\trekstor-dvb-dab-stick\DAB_Player_1-0-2-159_de-en-fr-it-nl-no-pl\ffdshow.ax)
An these other infosRTKDAB.dll: 1.1.1027.2010 (C:\Windows\SysWOW64\RTKDAB.dll)
Please use the version "with Logfile" and provide the logfile here.transistor hat geschrieben: ↑Fr 22. Mai 2020, 10:59...
5) When I try to listen to a station, nothing happens (see picture 2, it remains like this)
Best regards,
Andi
Standort: München-Bogenhausen
Dear Andi
Thanks, Here attached.
I see some lines with "failed"
19:11:16.872 | CFilterGraph::ConnectPktDataParser(), ERROR: FindMatchingPin(PacketStreamOutput) failed with 0x80040216! Error description: 'Impossibile trovare l'oggetto o il nome ricercato.'
19:11:16.872 | CFilterGraph::Run() - ERROR: ConnectPins() failed!
19:11:16.872 | CDABPlayer::Play(), m_pGraph->Run() failed!
Mario
Mario
- Dateianhänge
- 2020-05-22_190700_DABPlayer_logfile.txt
- (211.76 KiB) 16-mal heruntergeladen
Please try the following (while the Software is not running):
1) Download the "Treiber1.zip" from here: https://www.ukwtv.de/cms/index.php?opti ... eiber1.zip
2) Open the downloaded .zip file with e.g. WinZip
3) Copy the file\DATA\RTKDABSOURCE.dll from the zip archive to C:\Windows\SysWOW64 (overwrite existing file)
Then try to start the DAB Player again.
Best regards,
Andi
Dear Andi
...SUCCESS!!
Actually just copying the RTKDABSOURCE.dll did not have any effect.
I noticed that the other DLLs in the same \DATA\folder in Treiber 1 were newer than the versions in C:\Windows\SysWOW64, so I copied them all, overwriting the original ones.
And... suddenly it started working
Thanks! This was a super-advice.
Great work!
Mario
...SUCCESS!!
Great work!
Mario
Wäre es eigentlich möglich, die Senderliste ganz links viel breiter anzusetzen ?
Hab schon verstanden daß alle Fenster rigide aufgebaut sind ( ausser dem SlideShow Fenster ), aber auf heutigen Bildschirmen sehen die Module ein wenig verloren aus.
Und diese immer sichtbare Liste ist viel praktischer als die im Speicher DropDown.
Was muss man neben der Software QIRX noch installieren damit es funktioniert? Hab einen QIRX Database Access Error der mir angezeigt wird.
Über den DABPlayer funktioniert das DAB Radio mit meinem MSI Digi VOX Mini Deluxe mit dem RTL 2832U.
Diese Frage ist im Thread zu QIRX besser aufgehoben: viewtopic.php?f=11&t=56472&sid=67faea50 ... 087a22e501Michinho2911 hat geschrieben: ↑So 24. Mai 2020, 18:32 Was muss man neben der Software QIRX noch installieren damit es funktioniert? Hab einen QIRX Database Access Error der mir angezeigt wird.
Viele Grüße,
Andi
Vor einigen Jahren hatte ich den Terratec T-Stick+ mit dem DAB Player verwenden können. Jetzt möchte sich der Treiber 6 nicht installieren lassen.
Hier läuft Windows 10 Version 2004 (Build 19041.264). Habe auf Kompatibilitätsmodus und Windows 7 versucht aber die Installationsroutine bricht ab mit dem Hinweis dass das Setup nur bis Windows 7 läuft.
In älteren posts wurde erwähnt dass man zuerst den Treiber 1 installieren sollte, dann den 6. Ebenso die Visual C++ Redistributable für Visual Studio 2019 32bit+64bit. Alles versucht aber negativ.
Was kann ich noch versuchen bevor ich einen alten Rechner (oder vmware als Notlösung) mit Windows 7 dafür einsetzen muss ?
Stichwort Zadig. Diesen Treiber installieren, und über rtltcp den Andi DAB Player starten.
Einfach einige Seiten zuvor hier durchlesen.
Vielen Dank.
Wenn ich mich recht erinnere gab es früher immer das Problem dass ich entweder Zadig für SDR basierte Programme verwenden musste und Treiber 6 für den DAB Player. Ich behalf mich immer damit, Zadig im Host System und Treiber 6 in der vm zu installieren was aber manchmal zu Aussetzern beim Abspielen führte.
Jetzt reicht wohl Zadig um den Stick mit diversen Programmen zu nutzen mit maximaler Performance.
Nachdem ich nun eine Stunde nicht nur die letzten Seiten hier im thread erfolglos gesucht und den Zadig Treiber von der Entwicklerseite geladen und zu installieren bin ich nun am Punkt auf eure Hilfe zu hoffen.
Vielleicht kommen auch die zuvor installierten Treiber 1 (den ich inzwischen mit dessen Deinstallationsroutine entfernt habe) und die Visual C++ Redistributable für Visual Studio 2019 in die Quere. Werden die noch benötigt ?
Braucht's auch noch den Treiber 6 ?
Der Terratec T-Stick+ wird hier als Bulk-In Interface (Interface 0) und Bulk-In Interface (Interface 1) erkannt. Beiden habe ich über Zadig den WinUSB Treiber zugewiesen. Ist das korrekt oder muss es ein anderer Treiber sein ?
Sieht nicht so aus denn wenn ich DAB_Player.exe öffne erscheint als Fehler "Stellen Sie sicher, dass ein DAB/TV-Stick mit Realtek-Chipsatz angeschlossen ist. "
