Panisher
Beitrag von Panisher »
WillyTP hat geschrieben: Mo 21. Sep 2020, 23:41 Any advice?
You might need to use the Astrometa settings tool to switch the stick from DVB-T2 to DAB mode.
Download the tool from here. Unzip and start the AMDVBT2Test.exe, wait for the selection to show up and then change it to "FM/DAB". Now you should be able to start the DAB Player. Note that you will need to do this everytime you want to use the DAB Player - even after just closing and re-opening DAB Player. It should work with the stock drivers without any additional modifications or installations. I don't know if there is any better way to avoid the need for changing to DAB mode explicitely each time. This is not my primary stick for DAB and probably the reason why it's just laying in a drawer right now.
WillyTP
Beitrag von WillyTP »
Hi,
thank for your reply.
Unfortunately I'm not able to use DAB Player neither by using AMDVBT2Test.exe
I've opened my stick: just for knowledge, my one has demodulator Sony CXD2837ER.
Panisher
Is there any other error than the DAB stick not found message?
In my case, I get an exception before the not found message indicating to me that I have to switch the mode to DAB again. I don't use this stick regularly but I had the same driver version as you.
MatiasM
Beitrag von MatiasM »
Dab player not working with lastes driver for Astrometa (AMDVBT2_Setup64_191226)
With older driver (AMDVBT2 BDA Driver 170427), first run claims that the tuner from realtek has not been connected, second run dab player work well.
http://www.astrometa.com.tw/integrated_en.html
I think I have 2018 version becouse Linux show Sony chipset, but in a 2014 package (USB\VID_15F4&PID_0131&MI_00)
https://linuxtv.org/wiki/index.php/Astrometa_DVB-T2
Panisher
You are right. The 191226 driver package does not work. The driver files (AMDVBT2BDA.sys, AMDVBT2USB.sys) have the same version number as in the 170427 driver package but are of different size. The Realtek DLLs are missing from the new package as well. I was fooled by the driver version being same but actually had the older versions (170427) installed. So simply use the old driver and start DAB Player twice.
Andi_Bayern
Neue Version 1.0.2.161
Beitrag von Andi_Bayern »
andimik hat geschrieben: Di 12. Mai 2020, 22:56 Also ich würde vorschlagen, das Fenster länger bestehen zu lassen, so dass man das Thank you (ich glaube, das konnte ich kurz erkennen) lesen kann.
Es gibt eine neue Version 1.0.2.161 mit folgender Neuerung:
- Status-Fenster für Upload zur Dablist im Suchlauf-Dialog wird nicht mehr automatisch geschlosssen
Download:
- Für Windows: DAB_Player_1-0-2-161_de-en-fr-it-nl-no-pl.zip
- Für Windows, mit Logfile: DAB_Player_1-0-2-161_de-en-fr-it-nl-no-pl_withLog.zip
- Experimentell: Für Linux (WINE): DAB_Player_1-0-2-161_de-en-fr-it-nl-no-pl_WINE.zip
- Experimentell: Für Linux (WINE), mit Logfile: DAB_Player_1-0-2-161_de-en-fr-it-nl-no-pl_WINEwithLog.zip
Viele Grüße,
Andi
Standort: München-Bogenhausen
Ein Darstellungsfehler mit Version 160 der aber mit der 161 scheinbar behoben wurde. Das Bild im Original gibt es gleich mit dazu.
Das muß Kesseln
Beitrag von Das muß Kesseln »
OT Aus Mangel des Empfangs benötige ich im Moment keinen neuen Dab Player ;) Alles ziemlich nervig wenn der Stick kaum Pegel hat überstern die Radios wieder da der Verstärker der den Stick auf Trapp bringt die Radios überfordert :D Folglich verzichte ich auf den Rechner der eh eine HF Schleuder ist.OT aus
Ist das Bild tatsächlich im Hochformat?
andimik hat geschrieben: Di 6. Okt 2020, 15:45 Ist das Bild tatsächlich im Hochformat?
Natürlich, somit passt es genau um es auf dem Handy in dem Format zu teilen.
zwhd
Beitrag von zwhd »
@pomnitz26
Was meinst du mit in 161 behoben wurde, zeigts doch genauso nicht richtig an?
Das muß Kesseln
Also das sollte wirklich egal sein ob Hoch oder Querformat..
zwhd hat geschrieben: Di 6. Okt 2020, 17:06 @pomnitz26
Wird da bei mir jedenfalls richtig angezeigt.
Ingo-GL
Beitrag von Ingo-GL »
Auf dem Sensia wird es genau richtig im Hochformat dargestellt, mittig auf dem Bildschirm mit schwarzen Zonen links und rechts. Und das Bild entspricht dem Standard, d.h. im Standard ist beschrieben wie ein Receiver in solchen Fällen vorzugehen hat.
Edit: Klarstellung, dass es auf dem Sensia richtig im Hochformat dargestellt wird.
Zuletzt geändert von Ingo-GL am Di 6. Okt 2020, 17:47, insgesamt 2-mal geändert.
zwhd
Beitrag von zwhd »
Bei mir nicht, nur im Cache ist es im richtigen Format. Bei dem normalen Slideshow Fenster ist es bei mir abgeschnitten.
