Ok,das kam damals nicht so rüber
Some things to check:Aurelien08 hat geschrieben:...
I have the NOXON DAB STICK v2 and work with the "treiber1" but when i try to see the RTBF slideshows in the SLS file, no reception appear...
- Please try the current version of DAB Player (1.0.2.140)
- Check if your DLL versions are correct: Right click into DAB-Player window, select "About DAB-Player". In the appearing "Info" window, then please check the version of RTKDAB.dll - for Treiber 1 it should be 1.1.714.2011
Best regards,
Andi
In one of the next versions, I'll switch to WASAPI for audio output, thus then the "Media Feature Pack for N versions of Windows" will no longer be required for running DAB Player on N or KN editions of Windows.Jarod hat geschrieben:...
Please update some readme/howto file somewhere to explain this to people.
A lot of developers use the N version.
And since 126 works but 130 does not, this Media Package should not be required. But this of course is the program creator's choice.
Best regards,
Andi
Hi Andy,
Sorry i have make a mistake, i'm using the treiber 3 for the NOXON DAB STICK V2 with this version of DLL: RTKDAB.dll: 1.1.520.2012 (C:\Windows\SysWOW64\RTKDAB.dll)
The software "USB Device Tree Viewer" turn back this information:
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : NOXON DAB Stick (Rev.2)
Device Path : \\?\usb#vid_0ccd&pid_00e0#00000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_0CCD&PID_00E0\00000001
Hardware IDs : USB\VID_0CCD&PID_00E0&REV_0100 USB\VID_0CCD&PID_00E0
Driver KeyName : {4d36e96c-e325-11ce-bfc1-08002be10318}\0007 (GUID_DEVCLASS_MEDIA)
Driver : C:\Windows\System32\Drivers\RTL2832UUSB.sys (Version: 64.1.106.2011 Date: 2011-12-15)
Driver Inf : C:\Windows\inf\oem128.inf
Legacy BusType : PNPBus
Class : MEDIA
Class GUID : {4d36e96c-e325-11ce-bfc1-08002be10318} (GUID_DEVCLASS_MEDIA)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : RTL2832UUSB
Enumerator : USB
Location Info : Port_#0001.Hub_#0004
Location IDs : PCIROOT(0)#PCI(1A07)#USBROOT(0)#USB(1)
Container ID : {1d8aa8ce-2b4c-5920-a8b7-ff76a45871ae}
Manufacturer Info : TERRATEC
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Upper Filters : RTL2832UBDA
Power State : D0 (supported: D0, D3, wake from D0)
I have updated DAB Player with the latest version v1.0.2.140 but it's the same issue.
Thanks for your help and your work.
Best regards,
Aurélien.
Class : MEDIA
Enumerator : USB
Problem Code : 0
Best regards,
Aurélien.
You could try the following:Aurelien08 hat geschrieben:...
1) Make a copy of your current RTKDAB.dll (just in case something goes wrong)
2) Download Treiber 1 and extract the .zip File
3) Copy RTKDAB.dll from Treiber 1 (subfolder \DATA) to C:\Windows\SysWOW64 (replace the existing file)
Best regards,
Andi
Hi Andy,Andi_Bayern hat geschrieben:You could try the following:Aurelien08 hat geschrieben:...
Best regards,
Andi
Something best look happen, i have now the slideshow windows appear but no slideshow for this moment, my signal is too week at home. We need more RTBF tester people for try with the RTKDAB.dll from the treiber1 and if possible with a better signal!
somebody can test it?
Best regards,
Aurelien.
[attachment 10423 rtbf_dll_modif.JPG]
Just tested it now, replace my RTKDAB.DLL from treiber2 with the treiber1 one... no signal.
I return to treiber2 dll
For sticks with Treiber 2 and Treiber 4, this is not possible.olilesp hat geschrieben: Just tested it now, replace my RTKDAB.DLL from treiber2 with the treiber1 one... no signal.
It's only possible for sticks with Treiber 3, 5 and 6.
Best regards,
Andi
pure fm Bayern ist wieder ON AIR
Found in another DAB Player issueAurelien08 hat geschrieben: Hi Andy,
I have the NOXON DAB STICK v2 and work with the "treiber1" but when i try to see the RTBF slideshows in the SLS file, no reception appear... Very strange format for the RTBF multiplex.
[attachment 10413 sls_rtbf.JPG]
Best regards,
Aurélien.
If this could help someone to fix this issue... This is another way to transmit PAD and slides.Signalling for this separate data stream is done in the FIC:
FIG 0/2 signals an additional packet data component for the service, with a ScId
FIG 0/13 signals that this component contains a Slideshow (actually this was also required for X-PAD slideshow, but is currently not required in DABlin's code, as it is implicitely detected just by its presence in the X-PAD, to keep it simple)
FIG 0/3 maps the ScID to a specific subchannel and a specific packet address (it is possible to have more than one transmission on the same packet data subchannel)
All this has to be combined and furthermore the packet mode has to be implemented, to extract the respective data from the packet mode subchannel. So this is a bit complex
So far I was not aware of any DAB services that currently use a separate subchannel for the Slideshow (in Germany this was done some years ago for 90elf). Therefore I did not yet add support to DABlin's data service processing. But it seems that there is demand for it
Have a nice weekend !
Seems this is from github.com
Re: Neue Version 1.0.2.139
Was kann man eigentlich dagegen tun, dass einem dieses selten dämliche Windows 10 immer wieder ungefragt diese 2009-Version drüber bügelt? Ich weiß nicht, wie oft ich dieses Problem schon hatte, immer wieder auf dem selben PC wohlgemerkt!Andi_Bayern hat geschrieben:Da hat er dir garantiert den "berüchtigten" Treiber von 2009 installiert. Prüf' bitte mal im Gerätemanager die Treiberversion des des Sticks.Staxe hat geschrieben: Mein altes Windows 7 Laptop hat gerade ein Update erhalten - es wurde im Hintergrund installiert - seit dem funktioniert DAB Player nicht mehr. Bereits während der Installation - brach der Empfang ab.
Viele Grüße,
Andi
O&O ShutUp10Habakukk hat geschrieben:Was kann man eigentlich dagegen tun, dass einem dieses selten dämliche Windows 10 immer wieder ungefragt diese 2009-Version drüber bügelt? Ich weiß nicht, wie oft ich dieses Problem schon hatte, immer wieder auf dem selben PC wohlgemerkt!Andi_Bayern hat geschrieben:Da hat er dir garantiert den "berüchtigten" Treiber von 2009 installiert. Prüf' bitte mal im Gerätemanager die Treiberversion des des Sticks.Staxe hat geschrieben: Mein altes Windows 7 Laptop hat gerade ein Update erhalten - es wurde im Hintergrund installiert - seit dem funktioniert DAB Player nicht mehr. Bereits während der Installation - brach der Empfang ab.
Viele Grüße,
Andi
Ohne irgendwelche lästige zusätzliche Software zu installieren dürfte das hier auch so funktionieren : https://www.deskmodder.de/wiki/index.ph ... Windows_10
@Chief Wiggum:
So etwas in der Richtung hatte ich auch schon gefunden. Mich stört nur daran, dass man die automatische Treiberaktualisierung nur generell ein-/ausschalten kann.
Noch ein Hinweis am Rande: wenn ihr manuell die 2009er Treiber durch die korrekten ersetzen wollt und es euch so geht wie mir, dass sich Windows 10 komplett mit der Meldung verweigert: "Windows hat festgestellt, dass die besten Treiber für das Gerät bereits installiert sind", dann gibt es folgenden Weg.
- Erst mal das Gerät mit dem falschen Treiber deinstallieren, also Rechtsklick im REALTEK Gerätemanagereintrag und "Gerät deinstallieren"
- Eingabeaufforderung und in das Verzeichnis wechseln, in dem der gewünschte Treiber liegt
- pnputil /add-driver RTL2832UBDA.inf (damit fügt ihr den richtigen Treiber zum Treiberspeicher hinzu)
- pnputil /enum-drivers (damit listet ihr alle Treiberpakete aus dem Treiberspeicher), ihr solltet nun 2 Einträge für Realtek haben,bei mir sah das z.B. so aus:
- Der obere Eintrag ist das Treiberpaket, das weg soll, das geht mit pnputil /delete-driver oem12.inf
Jetzt Stick wieder rein, es müsste ab jetzt wieder der korrekte Treiber verwendet werden. Bis zum nächsten Windows-Update, wenn ihr die Treiberaktualisierung nicht deaktiviert habt.
Veröffentlichter Name: oem12.inf
Originalname: rtl2832ubda.inf
Anbietername: REALTEK
Klassenname: Audio, Video und Gamecontroller
Klassen-GUID: {4d36e96c-e325-11ce-bfc1-08002be10318}
Treiberversion: 03/04/2009 [b]64.1.304.2009[/b]
Name des Signaturgebers: Microsoft Windows Hardware Compatibility Publisher
Veröffentlichter Name: oem61.inf
Treiberversion: 05/21/2012 [b]64.1.521.2012[/b]
