DAB News International
Re: DAB News International
interessiert haette mich die Slowakei? Ist dort etwas geplant? bzw. in Erwartung? was DAB betrifft..?
Bzgl. Slowakei habe ich noch nichts gehört, da scheint es auch noch nie Tests gegeben zu haben, im Gegensatz zu Tschechien.
Steht schon im Ö-Forum ...
http://radioforum.foren.mysnip.de/read. ... 48,1146713
Außerdem ist das überhaupt noch nicht fix, zuerst wird - wie in Österreich - bis Juli eine Abfrage durchgeführt.
Wenn man meine Meldungen schon abschreibt, dann bitte richtig ...
So sehen die Chinesen den Einsatz für DAB - als Ergänzung zum Radio:
[size=x-small](CQUPT = Chongqing University of Posts and Telecommunications)[/size]
The Microelectronics Laboratory of CQUPT has focused on the public application of DAB for several years and made progresses in various directions. Its work proves that DAB can have a wide range of applications on campus, in community and as an alarm system.
Taking DAB on the CQUPT campus as an example, it is used for examinations, not only for listening tests but also to announce rules in voice/text before tests, to give instructions and messages in text during tests. Although FM can be used for listening (not as good quality as DAB), it cannot deliver digital messages, and other techniques cannot provide data to many terminals at exact same time. DAB is also used for releasing administrative information and broadcasting courses in audio and video. So DAB is ideal for educational use and it has actually become a facility of the university.
China suffers frequent disasters, such as earthquakes and cyclones. South-east Asian countries also suffer many cyclones and tsunamis. In these countries, an authoritative alarm network based on DAB can be built. All sorts of terminals such as screens, LEDs, loudspeakers and radios could be used to issue alarm and give instructions to evacuate, along with maps, warnings and other useful information. After a disaster, DAB could be used to deliver messages to manage evacuation, and to coordinate medical, fire brigade and rescue staff. In extreme situations, when all communications and transport are cut off, an isolated place could establish communication with the outside world, if it has a local DAB transmitter, even a low power one, in operation.
People now tend to rely on mobile phone and internet too much but ignore their limitations. In many situations broadcasting is the most reliable and easy solution. We need to explore what DAB can do as a compliment to mobile phone and internet.
For these applications, relevant techniques need to be developed. Fortunately, DAB standards are capable of supporting such applications. The workshop is a good opportunity to introduce and demonstrate their operation to delegates.
Technical sections and Demonstrations
•DAB for education in CQUPT
•DAB for public-service information-provision and multimedia terminals
•Emergency communication using DAB channels
•Low power portable local DAB transmitter
Forum and Discussions
•DAB for education
•DAB for transportation and tourism
•DAB for emergency communication
•DAB techniques for public applications
•Products and market for public applications
(WorldDMB-Workshop in China, 21.-22. Oktober 2013)
http://www.worlddab.org/events/detail/329
•DAB for education
...folgendes ist zwar leicht OT, passt aber in die vorgehende Meldung...
Das obige Posting wird auch in Deutschland diskutiert, resp. teilweise getestet und angewendet.
Auszug aus dem Meinungsbarometer über die Medientage 2013
Im Autoradio läuft gerade der Titel “Nur noch kurz die Welt retten“ von Tim Benzko.
Plötzlich wird das Programm unterbrochen und eine Durchsage meldet eindringlich:
„Achtung Hochwasserwarnung; die Pegelstände der Elbe erreichen jetzt die Fünf-
Meter-Marke. Die Bevölkerung aus dem Einzugsgebiet wird sofort evakuiert.“ Direkt
nach der Notfalldurchsage schaltet das Gerät wieder auf den Song im Radio um.
Eine solche lebensrettende „Emergency Warning Message“ im Katastrophenfall kann
unabhängig davon, welches Radioprogramm gerade gehört wird, übertragen werden.
Theoretisch. Im DAB-Standard ist eine solche Funktion bereits vorgesehen, genutzt
wird sie derzeit allerdings noch nicht.
Johannes Trottberger, Geschäftsführer der Bayern Digital Radio GmbH (BDR), will
das ändern. Derzeit testet die BDR gemeinsam mit dem Fraunhofer-Institut für
Integrierte Schaltungen (IIS) in Erlangen das Emergency Warning System (EWS)
Schnelle Information für den Katastrophenfall
Erste Tests für „Emergency Warning System“ über Digitalradio
Deutschlandradio präsentierte mobile Dienste auf und untersucht, ob herkömmliche
Digitalradio-Geräte Notfallmeldungen überhaupt empfangen und ausspielen können.
Johannes Trottberger sagt: „Für die Öffentlichkeit zeigen wir auf einem Noxon-Gerät
auf den Medientagen München, wie dieses System funktioniert. Das Noxon ist übrigens
das einzige Digitalradio, was EWS bereits heute unterstützt.“ Als nächster
Schritt sei es wichtig, die oberen Meldebehörden und insbesondere die Bayerische
Staatskanzlei über Möglichkeiten und Notwendigkeit dieses Systems zu informieren.
Olaf Korte, der das Projekt von Seiten des Fraunhofer-Instituts begleitet, erklärt, dass
man bei der Präsentation auf den Medientagen München sogar noch einen Schritt
weiter geht: „Wir demonstrieren mit dem EWS die spezielle Nutzung des über Digitalradio
übertragenen Textdienstes Journaline für Notfall- und Katastrophenmeldungen. Diese
werden somit nicht nur akustisch übertragen, sondern zusätzlich auch als Warnhinweis
in Form einer Textnachricht. Das kann gerade für Hörgeschädigte oder auch nicht
deutschsprachige Menschen extrem wichtig sein“, so Korte. Ein Beispiel: Im Katastrophenfall
blinkt eine LED am digitalen Radiogerät, dann erscheint ein Text auf dem Display
„Achtung: Katastrophenmeldung, weitere Informationen auf Journaline“.
Der über DAB+ ausgestrahlte Dienst Journaline wird auf den Medientagen nicht nur
auf dem Noxon-Gerät am Stand der BDR gezeigt. Seit Juli 2013 ist Journaline auch
als Option in allen BMW Baureihen und damit erstmals auch im Auto verfügbar. Mit
dem optional bestellbaren „Navi Professional“ sind unter anderem DAB+ und auch
Services wie Journaline empfangbar. Daher präsentiert das Fraunhofer-Institut Erlangen
einen BMW (M 135i) mit eingebautem Navi Professional auf der Messe. „Wir wollen
den Besuchern zeigen, wie Journaline im Fahrzeug integriert ist und wie es dort
bedient werden kann“, so Korte. Rund 20 Broadcaster bieten bereits Textnachrichten
über Journaline an, allen voran das Deutschlandradio mit einem umfangreichen Nachrichtenservice.
„Für Journaline ist es ein Meilenstein, dass man ihn jetzt auch im Autoradio
abrufen kann“, sagt Korte. Daher sei es für ihn wichtig, dass jetzt möglichst
schnell spezielle Journaline-Inhalte für Autofahrer entwickelt und angeboten werden.
http://www.barthelmarquardt.de/fileadmi ... n_2013.pdf
Anmerkung:
Natürlich darf in diesem Meinungsbarometer auch der VPRT mit seinem UKW/RadioDNS nicht fehlen. Die Graben wohl etwas aus, für dessen Verwendung es noch keine Endgeräte gibt. Er betont ja selbst, dass nur das Pure Sensia und das Revo Axim dafür geeignet sind. Das Noxon wird schön verschwiegen, da es sich ja um einen reinen DAB-Empfänger handeln könnte. Das Festhalten an der UKW-Technik ist natürlich beim VPRT in erster Linie Grundvoraussetzung für neue Radio-Dienste!
Anmerkung:
Und noch etwas zu neuen DAB-Tests, mitgeteilt von Carey (Wohnort):
May 8th
Tunisia listing updated. 12 services are reported being broadcast on Block 12C in Tunis.
May 8th
Monaco listing updated. 8 services are reported being broadcast in DAB+ on Block 8B.
May 8th
May 8th
Das mit Monaco steht im DAB Thread Frankreich, sorry, war kein anderer zu finden ...
Wieder mal einen Blick in die europäische Umgebung:
Anzahl Sendestandorte nach FMSCAN
Norwegen überrascht mich sehr, die sind doch nicht so lange dabei?
Auch die 657 in UK sind weit über dem, was ich mir vorgestellt hatte.
Austria
Azores
Belgium 35
Czech Republic 14
Denmark 130
France 27
Germany 234
Gibraltar 2
Hungary 3
Iceland
Ireland 10
Italy 120
Luxembourg 1
Madeira
Malta 3
Monaco 1
Netherlands 65
Norway 328
Poland 9
Portugal
Slovenia
Spain 5
Sweden 17
Switzerland 252
United Kingdom 657
Vatican City 4
Nicht jedes Land hängt seinen Ausbau an die große Glocke ...
Norwegen ist schon länger dabei, hat aber in den letzten Jahren auch extrem ausgebaut um das Ziel der UKW-Abschaltung zu erreichen. Im Endausbau sind es m.W. mehr als 600 Sender.
Portugal hat gar keine DAB-Sender mehr.
OK, das relativiert das ganze;-). Die Zahlen kamen mir schon ohne Nachzuzählen für Deutschland viel zu hoch vor (mit 234 *Standorten* käme man ja locker auf eine Abdeckung von weit über 95% der Fläche....).
In UK sind ja auch meist 2, teils 3 Muxe an einem Standort aktiv. In Deutschland sind es auch meist 2-3 Multiplexe, teils mehr. Und wenn wir schon STANDORTE diskutieren, müßte bei "Austria" ja auch "2" stehen - bei den Einzelsendern sogar mehr![Lächeln :-)](./images/smilies/icon_e_smile.gif)
Wenig überraschend:
http://www.parlament.gv.at/PAKT/EU/XXV/ ... 489511.pdf
L-Band nur in einem Land aktiv? Ich dachte, es sind 2 (CZE und I).
