rtl_tcp, an I/Q spectrum server for RTL2832 based DVB-T receivers
Version 0.89 for QIRX, Apr 2 2020
Found 2 device(s):
0: , , SN: á¾:é|
1: Realtek, RTL2838UHIDIR, SN: 00000001
Using device 1: Terratec T Stick PLUS
Found Elonics E4000 tuner
Sampling at 2048000 S/s.
Tuned to 100000000 Hz.
Tuner gain set to automatic.
Bandwidth set to automatic resulted in 2000000 Hz.
activating Response channel on port 1235 with inactive I2C reporting
listening...
Use the device argument 'rtl_tcp=127.0.0.1:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...).
listening on Control port 1235...
client accepted!
Control client accepted!
set bias tee 0
set sample rate 2048000
set tuner bandwidth to 2000000 Hz
Bandwidth parameter 2000000 Hz resulted in 2000000 Hz.
set gain mode 0
set agc mode 1
set bias tee 0
set freq 239200000
set freq correction 0
read registers 1
set tuner gain by index 0
set gain mode 0
set agc mode 1
set freq 239200000
set freq 239200000
set gain mode 0
set agc mode 1
set bias tee 1
set bias tee 0
set freq 176640000
set freq 178352000
comm recv bye
Signal caught, exiting!
worker cond timeout
all threads dead..
listening...
![:confused: :confused:](./images/smilies/smilie11.gif)
