AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
KejPi
Re: AbracaDABra - multiplatform SDR for RTL-SDR USB sticks
Beitrag von KejPi »
AbracaDABra version 1.99.3 has been released with following major changes:
  • UI changes
    • support for visual styles (dark mode supported on all platforms but only MacOS supports automatic switching)
    • expert mode switch moved to settings
    • DL+ can be disabled in settings
    • application no longer resizes when showing DL+
  • optional audio concealment using pink noise (only FAAD, can be configured in settings, disabled by default)
  • bug fixes and improvement
Binaries are available for download here: https://github.com/KejPi/AbracaDABra/re ... ag/v1.99.3
NOTE: this is probably the last testing version before 2.0.0. Please test and report problems, application should be stable enough for everyday use. Any feedback is welcome!
Please also allow to load the binary extension *.sdr (default file extension in Qt-DAB for dumps). Yes I have changed the drop down to 16bit...
Only workaround currently is to rename sdr to raw but this is not a good idea.
KejPi
Beitrag von KejPi »
No problem, I can add it in the next release. Is is it just raw 16bit IQ or is it this format? https://qirx.softsyst.com/RawXmlHeader
cain
Beitrag von cain »
Hello Kejpi, you can make it possible please to save 2 different packages on a channel ?
Not necessary. AbracaDABra will rescan the content on a channel anyway.
This is different to DAB Player!!!
KejPi
Beitrag von KejPi »
Not sure what do you mean by 2 different packages on a channel.
If you mean two different ensemble configurations, then you do not need it with AbracaDABra as written by andimik. The application updates the ensemble configuration each time you tune the channel and on top of that it fully supports ensemble reconfigurations for audio services, that means runtime reconfigurations of the ensemble are no problem for audio services. You may only hear short dropout if you listen to the service that changes audio coding or subchannel capacity. On MP2 (DAB) it is typically even without audio dropouts.
cain
Beitrag von cain »
In the first version of AbracaDABra for example, saved on 12c CRo DAB+ and SRG Swiss separate. Now it is overwriting every time.
KejPi
Beitrag von KejPi »
Yes, this is by design. One channel means one ensemble. If it changes then the application updates service list otherwise it makes not so much sense in my opinion. If 12C is occupied by CRo then what would you do with SRG?
Could you please be more specific about the use case - what exactly you do and what you expect the app should do?
cain
Beitrag von cain »
The app should save both I have a rotary antenna and can receive both.
Here you can see that it was possible earlier
AbracaDABra rescans each time.
You can receive them both, but not at the same time.
KejPi
Beitrag von KejPi »
andimik is right.
I am sorry, implementing what you are asking for would mean redesign of service list handling and it would cause a lot of issues for "normal" users.
You can have more INI files each with service list that is valid for particular antenna configuration. Then you can run the application with specific INI file using --ini command line switch. I think this way you can achieve the behavior you want to have.
cain
Beitrag von cain »
Ok thanks for the tip with the ini files
svenfl
Beitrag von svenfl »
Hello
Is it possible to create a Version that runs under MacOS 10.15.7?
regards Sven
KejPi
Beitrag von KejPi »
In theory yes, Qt6 should be supported, but I have no idea how to do it from Ventura. Does it mean that the Intel DMG I have released does not work? I have no possibility to test it, I have only MacOS Ventura running on Apple Silicon M1.
SeltenerBesucher
The current version only works with macOS Ventura. Even with macOS Monterey you get locked out. That was different with AbracaDABra version 1.2. This version still worked with older Macs. It's a pity that many users are not allowed to try out your new features. Apple's version policy is of course stupid and not environmentally friendly. Microsoft takes a similar approach and blocks many users from Windows 11. I would really appreciate backwards compatibility of your software.
